Formula language problem
madocar
I'm from Slovakia and I use excel in Slovak language.
I have set some formulas and when It's open in Czech republic, an error has occured.
The formula just does not work at all.
Sheet name:
Error_sheet
Formula Cell:
G5
Formula:
=D5-SUM(((Table_3[Začiatok prenájmu]<=$G$2)*(Table_3[Koniec prenájmu]>=$G$2)*(INDIRECT("'Prenajatá technika'!AL5:"&ADDRESS(ROWS('Prenajatá technika'!$DA$5#)+4;COLUMN('Prenajatá technika'!DA1);1;;))=F5)))
Error type:
#NAME?
Please could you help me out.
More in attachment
Thank you
Matt
  • Rezervácia skladu - chandoo ●.xlsm
madocar
Your G5 formula is different than Your above given ... why?
If You would use Your given formula with modification from $DA$5# to $DA$5
then for me it gives ... #VALUE!.
K-column formulas has some #REF!'s.
PS. Your Excel is newer than mine ... it give some notes too.
Your given filename has at least one illegal character.
Hi vletm,
thank you for replying.
K column - we can ignore.
Correct formula is with $DA$5#, so:
Does it work for you?
Look at my gif file how it might look.
Thank you
If they don't have M365 then the FILTER function that you have used would result in a #NAME? error which would then flow through your formulas, and the spill range syntax also won't work.
