In cell C3 I would like a formula to calculate the Total charges based on the Check In and Check Out dates. This needs to take into account the rates for the Seasons and if there are any Holidays in the date range which has the higher rate in P7. I put the amount in C3 by adding each day together as you can see in P10:R24 with the result in R25.
Thank you very much
Thank you very much
