First VBA macro work but the second doesn't work?
navic
I have a variable number of XLSX workbooks (product1, product2 ..... productX) from which I import data into Master.xlsm
I want to import from a closed workbook a certain range of cells 'B1: M19', which is in the same workbook in each workbook.
But I want to paste one below the other
My idea is to use a VBA macro for each workbook. So, if I have new workbooks, I add one VBA macro more.
- The first VBA macro works and copies the import range 'B1: M19' from the closed workbook to the active workbook 'Master.xlsm' in the 'Base' sheet into the cell range 'B1: M19'
- The other VBA macro doesn't work? This VBA macro should copy the range 'B2: M19' from the closed workbook to the active workbook 'Master.xlsm' in the 'Base' sheet to the cell range 'B20: M37'.
Can anyone tell why second VBA macro is not working and what lines of VBA code should be edited?
This is the VBA I use (I'm not sure how to create a VBA differently)
Sub Start()
    Call product1
    Call product2
Sub product1()
    Dim mydata As String
    Dim sPath As String
    Dim sFileName As String
    Dim sSheetName As String
    Dim sRange As String
    sPath = ThisWorkbook.Path & "\"
    sFileName = "product1.xlsx"
    sSheetName = "view"
    sRange = "B1:M19"
    mydata = "='" & sPath & "[" & sFileName & "]" & sSheetName & "'!" & sRange
    With ThisWorkbook.Worksheets("base").Range("B1:M19")
        .Formula = mydata
        .Value = .Value
Sub product2()
    Dim sPath As String
    sFileName = "product2.xlsx"
    sSheetName = "view"
    sRange = "B2:M19"
    With ThisWorkbook.Worksheets("base").Range("B20:M37")
        .Formula = mydata
        .Value = .Value
'Sub product3() etc etc.....
Plesae see attached workbooks (xlsx format).
Kenneth Hobson
In Master:
Sub Main()
  With Worksheets("Base")
    GetData .[B1:M19], ThisWorkbook.path & "\", "product1.xlsx", "view", "B1:M19"
    GetData .[B20:M37], ThisWorkbook.path & "\", "product2.xlsx", "view", "B2:M19"
Sub GetData(toRange As Range, sPath As String, sFileName As String, sSheetName As String, _
  sRange As String)
  toRange.FormulaArray = "='" & sPath & "[" & sFileName & "]" & sSheetName & "'!" & sRange
  toRange.Value = toRange.Value
Marc L
To load data from all 'Product' workbooks without 'empty zero' rows, paste this demonstration to the Sheet2 (base) worksheet module :​
Sub Demo1()
  Const C = 12
    Dim D$, F$, R&, L%
        D = Dir(ThisWorkbook.Path & "\product*.xlsx"):  If D = "" Then Beep: Exit Sub
        Me.UsedRange.Clear
    Do
        F = "='" & ThisWorkbook.Path & "\[" & D & "]view'!B"
        R = R + 1
        Cells(R, 2).Resize(4 - (R = 1), C).Formula = F & 2 + (R = 1)
        R = R + 4 - (R = 1)
    For L = 7 To 15 Step 4
        Cells(R, 2).Resize(3, C).Formula = F & L
        R = R + 3
        Cells(R, 2).Resize(1, C).Formula = F & "19"
        D = Dir
    Loop Until D = ""
    With [B1].CurrentRegion
        .Formula = .Value2
        .Cells(1).Clear
Marc L
As sometimes playing with formulas to load data from a closed workbook can be a mess​
for an unique cell I prefer to use the ExecuteExcel4Macro VBA method but for an entire worksheet like your 'view' attachment​
the way to use is the ADODB connection in particular for several source workbooks (paste to the Sheet2 (base) worksheet module) :​
Sub Demo2()
    Dim D$, oCn As Object, S$
        Set oCn = CreateObject("ADODB.Connection")
        S = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & ThisWorkbook.Path & "\#;Extended Properties=""Excel 12.0"
        Me.UsedRange.Clear
        oCn.Open Replace(S & ";HDR=No""", "#", D)
        [B1].CopyFromRecordset oCn.Execute("[view$1:1]")
        oCn.Close
        S = S & """"
    Do
        oCn.Open Replace(S, "#", D)
        Cells(Me.UsedRange.Rows.Count + 1, 2).CopyFromRecordset oCn.Execute("[view$]")
        oCn.Close
        D = Dir
    Loop Until D = ""
        [C2].Resize(Me.UsedRange.Rows.Count - 1, Me.UsedRange.Columns.Count - 1).NumberFormat = "#,##0.00"
        Set oCn = Nothing
Marc L
To load 'view' data without any blank row the second Execute SQL string (the one within the Do Loop block)
must be amended like this : oCn.Execute("[view$] ]WHERE F1>''") …​
Another SQL syntax : WHERE F1 IS NOT NULL …​
You may Like this !​
