Finding MAX value using an Array.
Attached is an excel where few common details are mentioned in Col. A and in Col. B corresponding dates are mentioned.
I need a formula in Col. E1 that, if I input any value of Col. A in Col. D1 then the system should show the max. date in Col E1.
I tried the following formula but it is not working.
={MAX(IF(D1="MV",(VLOOKUP(D1,A1:B12,2,0)),""))}
Fluff13
How about
=MAX(IF(A1:A12=D1,B1:B12))
Confirmed with Ctrl Shift Enter
Or if you have the maxifs function
=MAXIFS(B1:B12,A1:A12,D1)
Peter Bartholomew
Your existing formula looks up a single value and then applies the MAX function, which is too late to be useful.
I would go with @Fluff13 's formulas
= MAXIFS(dates, details, criterion)
or for old versions of Excel
= MAX( IF(details=criterion, dates ) )
It is possible to use the look up functions though. The common strategy is that you must filter the dates first and then, to find the maximum, you look up a date that you know to be larger than anything that occurs in the table using an approximate match.
= LOOKUP( today, IF(details=criterion, dates) )
= LOOKUP( today, dates/(details=criterion) )
= VLOOKUP( today, IF(details=criterion, dates), 1)
Using Office 365
= XLOOKUP( today, dates/(details=criterion), dates, , -1 )
= XLOOKUP( today, IF(details=criterion, dates), dates, , -1 )
or finally,
= MAX( FILTER( dates, details=criterion ) )
AlanSidman
With Power Query, Mcode follows
let
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Column1", type text}, {"Column2", type date}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"Column1"}, {{"Max Date", each List.Max([Column2]), type date}, {"Data", each _, type table [Column1=text, Column2=date]}}),
    #"Removed Columns" = Table.RemoveColumns(#"Grouped Rows",{"Data"})
in
    #"Removed Columns
vAB
1Column1Max Date
2MV1/17/2020
3FV1/19/2020
4MS1/21/2020
5SV1/23/2020
Peter Bartholomew
@AlanSidman
That would do it, especially if the data access requires an ETL step. Mind you, at least I get a rational date format of 17/1/2020 from PQ :)
If I upped the game with the formula
= XLOOKUP( IF({0,1},today,0), dates/(details=criterion), dates, , {1,-1} )
to simultaneously calculate earliest and latest dates, what would be the neatest PQ approach?
Peter Bartholomew
@Khalid NGO
Two more that I missed! Since I have yet to delete the workbook, I added
= AGGREGATE(LARGE, IgnoreErrors, 1/(details=criterion)*dates, 1)
= SUMPRODUCT( MAX((details=criterion)*dates) )
I would, though, classify both as array formulas. One of the few areas in which 'old Excel' actually worked correctly!
@AlanSidman
I also discovered that PQ performs multiple grouped calculations simultaneously.
let
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"details", type text}, {"date", type date}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"details"}, {{"minimum", each List.Min([date]), type nullable date}, {"maximum", each List.Max([date]), type nullable date}})
in
    #"Grouped Rows"
If I stick around long enough, I might even learn something!
Thank you, Experts and Camps, but I can't use Pivot in my report. I have to stick with VLOOKUP, as a change in the report means loads of work to be redone.
Making my case very simple, I am attaching new workbook where :
Worksheet DelvStatus: Contains delivery details, from where I am picking up date (col C) by referring col. B for VLOOKUP reference.
Worksheet Data: This sheet contains my actual raw data (trimmed to required one), where I am using the VLOOKUP formula in Col. H for getting the newest date.
Now the problem is that, for BTID 4778, it has been delivered 4 times on different dates (29-Nov-18, 21-Dec-18, 08-Jan-19, 27-Jan-19), which is recorded in DelvStatus sheet.
And in Data sheet I am expecting the newest date under Col. H for BTID 4778. However, I am getting the oldest date (29-Nov-2018). Here I am expecting 27-Jan-19.
deciog
Hi vaidmohammed
Use this way
=IFERROR((IF(G2="Delivered",LOOKUP(2,1/(DelvStatus!$B:$B=A2),DelvStatus!$C:$C),"")),"No Data Present")
Decio
