Find Top 3 Applications using formula
ajoshi76
Hello All,
I have a table having the following columns:
1. Resource Name
2. Month
3. Application Name
4. Ticket Id
Can anyone tell me how to find out the Top 3 Application Name for a particular resource for a particular month?
Hi Joshi ,
You can try the following construct :
=INDEX(Application_Names,SMALL(IF(Resource_Names=Particular_Resource,IF(Months=Particular_Month,ROW(Application_Names)-MIN(ROW(Application_Names))+1)),ROW(A1)))
entered as an array formula , using CTRL SHIFT ENTER.
Copying it down , will change the ROW(A1) to ROW(A2) , ROW(A3) ,... which will give the second and third top application names.
Thanks Narayan. i shall try this formula
But my table for reporting is as below:
Resource Name, Month, Top 3 application names
so the top 3 application names should comes in a single row.
Narayan -> the formula doesnt give the top application names.
eg:
If Resource A MOnth B has 3 applications: App1 has 5 tickets, App2 has 10 tickets and App3 has 1 ticket. The cell should say: App2, App1, App3
This is the end result i am looking for.
I fixed my formula to give the 1st top application having maximum tickets for a resource for a month
=INDEX('SN Dump'!$F:$F,LARGE(IF('SN Dump'!$G:$G=Table1[[#This Row],[Original Name]],IF('SN Dump'!$M:$M=Table1[[#This Row],[Month]],ROW('SN Dump'!$F:$F)-MIN(ROW('SN Dump'!$F:$F))+1)),ROW(A1)))
But i need all 3 applications in the same cell for a particular resource for a particular month.
Thanks a lot Narayan. It indeed did the job for me
The modified formula of the above thread is as below:
=CONCATENATE(INDEX('SN Dump'!$F:$F,LARGE(IF('SN Dump'!$G:$G=Table1[[#This Row],[Original Name]],IF('SN Dump'!$M:$M=Table1[[#This Row],[Month]],ROW('SN Dump'!$F:$F)-MIN(ROW('SN Dump'!$F:$F))+1)),1))," , ",INDEX('SN Dump'!$F:$F,LARGE(IF('SN Dump'!$G:$G=Table1[[#This Row],[Original Name]],IF('SN Dump'!$M:$M=Table1[[#This Row],[Month]],ROW('SN Dump'!$F:$F)-MIN(ROW('SN Dump'!$F:$F))+1)),2))," , ",INDEX('SN Dump'!$F:$F,LARGE(IF('SN Dump'!$G:$G=Table1[[#This Row],[Original Name]],IF('SN Dump'!$M:$M=Table1[[#This Row],[Month]],ROW('SN Dump'!$F:$F)-MIN(ROW('SN Dump'!$F:$F))+1)),3)))
New Situation: If there are only 3 tickets for a particular resource and all 3 belong to different application, i get #NUM as the result.
Need help.
This formula gives the top application:
Can someone review and fix if required.
Also, edit this formula to get top 3 APPLICATIONS?
the result of the above formula is wrong even for top application. Can someone immediately help. i am unable to progress any further
Hi Joshi ,
Sorry ; I made a mistake in my original posted formula ; I now understand that what you want is the top 3 application names , by way of the number of tickets against each application name. It will make it easier if you can upload your file.
Resource Name Month Application Ticket Id
Ashish Joshi Jun App1 1234
Ashish Joshi Jun App2 1235
Ashish Joshi Jun App1 1236
Rahul Jun App4 2134
Rahul Jun App1 1237
Rahul Jul App3 2348
Ashish Joshi Jun App1 1238
Ashish Joshi Jun App2 1239
Ashish Joshi Jun App1 1231
Rahul Jun App4 2138
Rahul Jun App1 1232
Rahul Jul App3 2349
The output should be in this table
Reosurce Name Month Top 3 Apps
Ashish Joshi Jun ???
Ashish Joshi Jul ???
Rahul Jun ???
Rahul Jul ???
Hi Joshi ,
Can you download the file from here and check ?
https://www.dropbox.com/s/ykgpgaefi1qxr2p/Example_Joshi.xlsx
I have used one helper column.
