percybukes
Hi
I have downloaded SAP transactions / reports and exported the data to different excel files. I don't make any other changes to these files.
I then "get data" from "workbook" and perform usual review to ensure data types etc are all correct.
There is one column with the "order number" that is common in all the downloads and resultant queries. This column is a whole number data type in all the queries.
I created a new query extracting only the order number column from each of the queries and then sorted this column and removed duplicates, to then create my "link query" to be used in the one-to-many relationship data model.
When i then create a pivot table it looks like the relationships don't work - for example:
when i drop the order number from the link query into the rows and then pull for example movement type from another query then all the movement types that exist in the query pull through and show against one specific order (I filtered to see only one order number), even though the data has only one movement type associated with that specific order in the underlying data file (and in SAP).
When is do a pivot table pulling the order number not from the unique link query but from the same query as the movement typer data is in, then i see the order number with only one movement type showing nest to the order - which is correct.
It seems as if the filtering is not working, but i cant figure out why.
Any help or pointers will be appreciated
Thank you
Percy
Thank you
Percy
