Niranjanrajrishi
My below code to assign formula and after the filter does not provide the desired result. When I use the code, it gives me strange output and result. Can you please help me?
After I filter, the desired range not found, then it should skip to next . I have a huge data and multiple formula needs to apply many places. If I can get a error free code, then I can use it.
Sample file attached.
Code: 1
Code: 2
Also is there any easy method to apply boarder and change the Font to Arial 10 (black color)?
Code: 1
Sub ModificationCriteriaOSVV()
Dim rng As Range
Sheets("OSV_Vendor").Activate
If ActiveSheet.AutoFilterMode Then ActiveSheet.Cells.AutoFilter
Rws = Cells(Rows.Count, "O").End(xlUp).Row
ActiveSheet.Range("$A$1:$AO$" & Rws).AutoFilter Field:=15, Criteria1:="Modification", Operator:=xlFilterValues
Set rng = ActiveSheet.Range("$A1$2:$AQ$" & Rws).SpecialCells(xlCellTypeVisible)
If Not rng Is Nothing Then
Set rng = Range(Cells(2, "N"), Cells(Rws, "N")).SpecialCells(xlCellTypeVisible)
If Not rng Is Nothing Then rng = "=C2&"" - ""&A2&"" - ""&O2"
With ActiveSheet
.AutoFilterMode = False
Code: 2
Dim rng As Range
ActiveSheet.Range("$A$1:$AO$" & Rws).AutoFilter Field:=15, Criteria1:="New creation", Operator:=xlFilterValues
If Not rng Is Nothing Then rng.Value = "=C2&"" - ""&A2&"" - ""&F2&"" - ""&O2"
With ActiveSheet
