Extracting String from a data with string
rom
Hey all , need urgent help.I am stuck with a VBA project because of this problem.I got a set of data which is seperated by symbol "/", the code i am trying to build is
if cell value is for eg ABC0604082/00797983 then result should be 00797983
if cell value is ABC0604082/ then result should be ABC0604082
I tried to do text to columns but the result doesn't have leading 0s, which means 00797983 is showing as 797983 & also it'll not belp me with my 2nd condition.
Please help
Rom
[pre]
Sub MyTxt()
Txt = "ABC0604082/00797983" 'then result should be 00797983
'Txt = "ABC0604082/" 'should be ABC0604082/
If Right(Txt, 1) = "/" Then
MsgBox Left(Txt, Len(Txt) - 1)
MsgBox Right(Txt, Len(Txt) - InStr(1, Txt, "/"))
[/pre]
Hi Rom... Use this.
Assuming the value is in A1, write
=text(if(right(A1,1)="/",left(A1,len(A1)-1),mid(A1,find("/",A1)+1,999)),"@")
This should extract either left or right portion while retaining leading zeros.
Hi Rom,
One more way assuming your data is in column A starting from Row 1.
[pre]
Public Sub SplitItUp()
Dim varSplit As Variant
For i = 1 To Range("A" & Rows.Count).End(xlUp).Row
varSplit = Split(Range("A" & i).Value, "/")
If Len(varSplit(UBound(varSplit))) Then
MsgBox varSplit(UBound(varSplit))
MsgBox varSplit(LBound(varSplit))
[/pre]
Hi all,
we may try this as well:
=If(Iserror(Find("/",A1))=True,A1,Trim(Mid(A1,Find("/",A1),999)))
Hi Rom,
I have a little bit longer trick.. No VBA, No Function.. only Recording.. :)
* Select Column.
* Text to Column.
* Delimeter > "/"
* Next > change both separated columns to TEXT.
* Now you have Two Column (ABC0604082 & (Blank or 00797983))
* Copy Column B.
* Paste Special in Column A, Skip Blanks..
* delete Column B.
Useful.. only in case of long list of Data, and want No Drag & Drop..
Deb
@ Shri..
Ha ha ha.. but in case of multiple "/" you will pass due to InStrRev.. and middle data will be overlooked..
unlike all other post... :) Which I think better for OP.
Deb
