Extract Unique data based on criteria
vletm
paradise
You can reread forum rules here:
There You can find eg next:
  • Also if you have cross-posted and get an answer elsewhere, have the courtesy of posting the answer here so other readers can learn from the answer also, as well as stopping people wasting their time on your answered question.
paradise
Dear all,
3Rd point is very important because if we receive our answer from any forum , we should have to link that answer here, its our responsibility to give credit to answerer.
We all are here to learn, & help each other to learn. Because that answer will be invaluable base for someone for learning. Also its give credit & respect to answerer & also fulfill them with fuel for help peoples. It's a matter of courtesy. Also even you can help readers to put that answer's link that also be a great help , like you received from other forum.
Chirag Raval
vletm
paradise
Of course, You could ... still waiting ...
Should You add more information - more clear rules - eq is 'few' something 50% or more
because Your 'unique records' seems to be something else?
( and You also should understand Forum view - ref Your #6 reply )
paradise
Ok.Let me explain.
1.First of all Unique record is to be extracted from B column.
2.Then,from First column i.e A Column that first matches with Step1,Secondly,it has to choosen from from C column on Priority basis.(1,2,3,4),combination can be any i.e (1,3),(3,2),(1,2,4),(2,4).Data to be taken of 1,2,1,2
3.For No code items,just arrange from C column on Priority basis matching similar as they slightly difference due to spelling error.
I now hope this will ease to all forum contributors.
paradise
Momentarily ignore this.How to do using advance filter as you have to do matching also as well as removable of Duplicates of B column excluding 'No code'data.As I have a very large data more than 2000.Practically,it has been a headache for me in solving it.
vletm
paradise
Could You explain that photo?
You expect something which is not in data.
If Your results are correct as those should expect, it won't help at all.
