Extract data from TXT file using VBA
Iodana
I have a .txt file from which I need to extract some data.
I need the following:
- account which is after ":25:/" - in this case FR73RDGC5482742933543197
- the opening balance which is after ":60F" and after the currency, in this case the opening balance is 70946035,10. To be noted that there are cases when it is either 60F or 60M.
- the closing balance which is after ":62M" and after the currency, in this case the closing balance is 70284085,42. To be noted that there are cases when it is either 62F or 62M.
- the currency, which is before the opening/closing balance, in this case RON
I need these populated in 4 columns in Excel: Account, Opening balance, Closing Balance and CCY
I have files where there are multiple accounts with opening and closing balances put one after another, so I should be comfortable that the right balances are taken for each account.
I attached the txt file below.
I would highly appreciate your help.
Thanks!
vletm
Iodana
How many rows of data do You sample file have?
If one row per file - okay
If more rows per file - then You would send a sample.
What kind of data would be in case if there are multiple accounts?
... a sample needs.
As well as - You would send here expected outputs based Your sample files.
Iodana
@vletm
i) I have multiple rows per file, this is only an example with one account, but there can be multiple accounts with balances in one file - I attanched an example.
ii) The data can differ from one account to another, as between the balances there can be multiple lines - this is not standard - the data is related to the movements between the opening balance and the closing balace and it is mapped with :61: & :86: - the format of the rows is pretty the same for all
iii) I attached an output file.
Thanks!
