excel vba progress Bar code required
ajayon
HI,
i required Excel Vba progress bar code if any one can help me
1) i required code for my sub procedure start to finished code 1 to 100%
or
2) i have mutiple excel sheet in side that excel sheets row by rows operation i required progress by to show -- 1 to 100%
till my code finished
3) or any other code related progress
Logit
Here is something you can review for your needs. This represents a part of the total code :
' Written by Philip Treacy, June 2016
' http://www.myonlinetraininghub.com/excel-progress-bar-for-vba
Sub Using_Collection_Loops_ProgressBar()
  Dim lngNumValues() As Long
  Dim strBorder As String
  Dim lngMin As Long, lngMax As Long
  Dim rng As Range, rngInput As Range
  Dim col As Collection
  Dim i As Long, j As Long, k As Long
  Dim varDummy As Variant
  ' CHANGE THIS PART TO DEFINE RUNS
  ReDim lngNumValues(1 To 5) As Long
  lngNumValues(1) = 10
  lngNumValues(2) = 100
  lngNumValues(3) = 1000
  lngNumValues(4) = 10000
  lngNumValues(5) = 50000
  ' THIS IS WHERE THE MAGIC HAPPENS
  ' Set up output table headers
  strBorder = String(92, "-")
  Debug.Print strBorder
    k = 1
      'Set up random numbers
      lngMin = 1
      lngMax = lngNumValues(5)
    'Initilaize the progress bar width
    InitProgressBar (lngMax)
      Cells.Clear
      Set rngInput = Range("A1").Resize(lngMax, 1)
      rngInput.Formula = "=RANDBETWEEN(" & lngMin & "," & lngMax & ")"
      Set col = New Collection
      ' First add all items to collection (ignore errors when duplicates are added)
      For Each rng In rngInput
          col.Add rng.Value2, CStr(rng.Value2)
        On Error GoTo 0
      Next rng
      ' Loop through every possible nubmer in range (error returned when number not found)
        For j = lngMin To lngMax
          varDummy = col(CStr(j))
          If Not Err.Number = 0 Then
            Debug.Print j
            Err.Clear
            'Must DoEvents to allow code to update bar and show it
            DoEvents
            ShowProgress (j)
        Next j
        CloseProgressBar
