Sajjad Haider
I found the below code in this website that copies the email body from a specified folder in outlook and pastes it to excel. However, the problem is I want a specific text only to be copied to excel. I inserted the email sample and I want the highlighted item to be copied.
@ Build: please add the following fixings in System(for 24-Dec-2018):
123456_ABC_Goal --- 123456789.20
123456_ABC_RiskFee --- 123456789.88
Public gblStopProcessing As Boolean
Sub ParseBlockingSessionsEmailPartOne()
' This macro requires Microsoft Outlook Object Library (Menu: Tools/References) be available
Dim wb As Workbook
Dim ws As Worksheet
Dim objFolder As Object
Dim objNSpace As Object
Dim objOutlook As Outlook.Application
Dim lngAuditRecord As Long
Dim lngCount As Long
Dim lngTotalItems As Long 'Count of emails in the Outlook folder.
Dim lngTotalRecords As Long
Dim i As Integer
Dim EmailCount As Integer 'The counter, which starts at zero.
On Error GoTo HandleError
'Application.ScreenUpdating = True
'Application.ScreenUpdating = False
Sheets("Merge Data").Select
' Initialize:
Set wb = ThisWorkbook
lngAuditRecord = 1 ' Start row
lngTotalRecords = 0
' Read email messages:
Set objOutlook = CreateObject("Outlook.Application")
Set objNSpace = objOutlook.GetNamespace("MAPI")
' Allow user to choose folder:#
Set objFolder = objNSpace.pickfolder
' Check if cancelled:
If objFolder Is Nothing Then
gblStopProcessing = True
MsgBox "Processing cancelled"
Exit Sub
lngTotalItems = objFolder.Items.Count
If lngTotalItems = 0 Then
MsgBox "Outlook folder contains no email messages", vbOKOnly + vbCritical, "Error - Empty Folder"
GoTo HandleExit
If lngTotalItems > 0 Then
wb.Worksheets("Merge Data").Delete
'wb.Worksheets("Audit").Delete
wb.Worksheets.Add After:=Worksheets(Worksheets.Count)
Set ws = ActiveSheet
ws.Name = "Merge Data"
'Insert Title Row and Format NOTE: THE MACRO CAN BE USED TO PARSE OUT OTHER PARTS OF AN EMAIL.
' I JUST COMMENTED OUT THE LINES NOT USED FOR THE CURRENT PROJECT.
'ws.Cells(1, 1) = "Received"
ws.Cells(1, 1) = "Email Body"
ws.Cells(lngAuditRecord, 2) = "Subject"
'ws.Cells(lngAuditRecord, 4) = "Attachments Count"
'ws.Cells(lngAuditRecord, 4) = "Sender Name"
'ws.Cells(lngAuditRecord, 5) = "Sender Email"
ws.Range(Cells(lngAuditRecord, 1), Cells(lngAuditRecord, 1)).Select
Selection.EntireRow.Font.Bold = True
Selection.HorizontalAlignment = xlCenter
'Populate the workbook
For lngCount = 1 To lngTotalItems
Application.StatusBar = "Reading message " & lngCount & " of " & lngTotalItems
i = 0
'read email info
While i < lngTotalItems
i = i + 1
If i Mod 50 = 0 Then Application.StatusBar = "Reading email messages " & Format(i / lngTotalItems, "0%") & "..."
With objFolder.Items(i)
'Cells(i + 1, 1).Formula = .ReceivedTime
Cells(i + 1, 1).Formula = .Body
Cells(i + 1, 2).Formula = .Subject
'Cells(i + 1, 4).Formula = .Attachments.Count
'Cells(i + 1, 5).Formula = .SenderName
'Cells(i + 1, 6).Formula = .SenderEmailAddress
Wend
'Set objFolder = Nothing
ws.Activate
Next lngCount
lngTotalRecords = lngCount
'Format Worksheet
Columns("A:A").Select
Selection.ColumnWidth = 255
Cells.Select
Selection.Columns.AutoFit
Selection.Rows.AutoFit
With Selection
.VerticalAlignment = xlTop
Range("A1").Select
' Check that records have been found:
If lngTotalRecords = 0 Then
MsgBox "No records were found for import", vbOKOnly + vbCritical, "Error - no records found"
GoTo HandleExit
With Selection
Cells.Select
.WrapText = True
Range("A1").Select
HandleExit:
Set objNSpace = Nothing
Set objOutlook = Nothing
Set ws = Nothing
Set wb = Nothing
If Not gblStopProcessing Then
MsgBox "Processing completed" & vbCrLf & vbCrLf & _
"Please check results", vbOKOnly + vbInformation, "Information"
'Call ParseBlockingSessionsEmailPartTwo
Exit Sub
HandleError:
MsgBox Err.Number & vbCrLf & Err.Description
Resume HandleExit
