Excel average excluding #DIV/0! but not in range
Vpremakumar
Hey guys,
Pls help me finding the solutions for below.
Name Number
A 10
B #DIV/0!
C 12
D #DIV/0!
E 20
F 13
G 18
I've to find out the average for names B,D,F,G using excel formula. Thanks
Can you replace the formulas in B & D with something to catch the errors and put a 0
eg: =IFERROR(existing formula,0)
Then do an average as normal =Average(B, D, F, G)
Hey, I'm looking for formula that it shouldn't consider error value itself to calculate average.With your formula it shows 0 instead of #DIV/0! but it'll consider 0 for average calculation.Is any other formula to calculate average excluding #DIV/0! and data are not in range. Please suggest. Thanks!
@xld
What does the ="B" part do?
I think you're okay using the slightly smaller array formula:
=AVERAGE(IF(ISNUMBER(B2:B10),B2:B10))
Looking at my formula, let's start at the inside and work out. The first function is an IF function, checking each cell within the range B2:B10 to see if it's a number. If it is, pass it on (True_arguement), otherwise do nothing (will return FALSE). Visually, if we start with this:
1
2
3
4
#DIV/0
John
4
5
The formula will convert to this:
1
2
3
4
FALSE
FALSE
4
5
The outer function is AVERAGE, which takes the converted section and averages it. The function ignores logicals/text, so we just get the average of 1,2,3,4,4,5. This is the desired outcome.
The formula needs to be confirmed as an array formula (use Ctrl+Shift+Enter to confirm, not just Enter) because we want the IF function to look at each cell with B2:B10, not treat the whole range as a single entity.
That's okay. Simply the formula to look at the entire range (containing numbers, text, errors) and it will only average the numbers.
