Equation with multiple vertical and horizontal conditions
Hany ali
Dear Sirs and Professors ,I want you Help in fount Equation to get the Result By Multiple Conditions
I want This Price From Data Sheet
by Four Conditions ,
1- Excursion Name
2- Supplier Name
3- Vechicle Type
4-By Transfer Region
and if Supplier Name =Supplier,we
will get Price From Supplier Column In Data Sheet and after that to
Multiply in pax Number in B Column
in Total Sheet without care by
Vehicle Type
but if i Choose Spring Tours ,
we will get the Result By this Four Conditions
  • Supplier1.xlsm
Hi @Hany ali ,
See if is ok ?
=INDEX(Data!$V$7:$AT$11,MATCH(Total!D2,Data!$U$7:$U$11,0),MATCH(H2,Data!$V$4:$AT$4,0)+MATCH(Total!G2,Data!$V$6:$Z$6,0)-1)
  • Supplier1.xlsm
hello Masters ,Please I want Your Helping to found another Formula for this way to get the same Result by Multiply Condition the same in the File
33545
  • Transfer2.xlsm
Try........
In G3, copied right to H3 and all copied down :
=IFERROR(OFFSET(Data!$A$1,MATCH(1,INDEX((Data!$A$2:$A$11=$B3)*(Data!$AL$4:$AL$11=$C3),0),0),MATCH($E3,Data!$B$2:$I$2,0)+MATCH($F3,Data!$B$1:$AK$1,0)+COLUMN(A1)-2),"")
66286
Bosco
