Put a list of names in say M1:M10
Then, ensure cell A1 is empty and goto Tools>Options and on the Calculation
tab check the Iteration checkbox to stop the Circular Reference message.
Next, type this formula into cell B1
=IF(($A$1="")+(AND(B1>0,$B1<>$C1,COUNTIF(B$1:B$10,B1)=1)),B1,RANDBETWEEN(1,10))
it should show a 0
Then, type this formula into cell C1
=IF(($A$1="")+(AND(C1>0,$B1<>$C1,COUNTIF(C$1:C$10,B1)=1)),C1,RANDBETWEEN(1,10))
In D1, enter
=INDEX($M$1:$M$10,B1)
and copy across to E1
Copy B1:E1 down to B10:E10.
Finally, put some value in A1, say an 'x', and all the random numbers will
be generated, and they won't change, and you will see unique name pairs.
To force a re-calculation, clear cell A1, edit cell B1 and C1, don't change them,
just edit to reset to 0, copy B1:C1 down to B10:C10, and re-input A1.
