Do if conditions met in Excel VBA
saamrat
If there is a value in Custom, Special Rate Should be Custom. If Custom field is blank, Special Rate should be Price 2. How to do this in excel VBA
Please Help.
Special RatePrice 1Price 2Custom
91089
5105
7107
vletm
saamrat
Where do You would like to get the result in above ... table?
You should upload a sample file which has sample data and needed correct results.
saamrat
Thank you for your response.
Kindly find the attached Sample Sheet.
If Column H has value, then column B Should be the value of H. Otherwise, Column B value must be of Column G. I input the formula in the cells.
Similarly, if there is a value in Column A, then Column C must be A*B. Otherwise, Column C is Blank.
Appreciate your help
saamrat
Wow!! you are a life saver Sir. As I am expected.
But there is a problem. If there a value already entered in the column A and if you try to change the value in column H, the multiplication in Column C is not happening. Kindly help.
