Distance Calculator for many addresses
bwarn
I have downloaded the Distance Calculator and it works great! Appreciate that it is available. I have a question. I have a group of addresses (< 1,000) that I need to calculate driving distance. How can I perform those driving calculations for the entire list of addresses rather than one by one?
Thanks for the help!
Bill
Peter Bartholomew
In general terms, if the Distance Calculator either is a Lambda function that produces a single output (or can be wrapped to turn it into a Lambda function) then BYROW will evaluate the function for each row and return the distances as a single array.
Alternatively, it might word by simply inputting the start and end points as arrays; it all depends on the calculator.
bwarn
Thank you both for replying. The one I found was created by Derry Hill on 7/17/2018. Essentially it allows entry for the Bing key and an origin and destination address. It generates multiple URL's and finally the distance and travel time at the bottom.
Peter, I will look at BYROW. That one is new to me.
Bill
