Displaying Current Activity in Project Portfolio Dashboard
AnnR
I've got a portfolio of roughly 30 projects, and need to create a way to display the current activity in a combined list on the dashboard ... I've played around with all kinds of different functions, but can't seem to find the right one. The data is set up as in the dashboard template:
Column B - Activity
Column C - Start Date
Column d - Duration
Column E - % complete
I'm open to using either the date or the % complete as a means of determining what the current activity is ... since any activity with a value between 0 & 100% would indicate it's in progress. Ideally, I'd want to use the date, and display the activity that is scheduled to occur in the upcoming week. Any help you can provide would be greatly appreciated!
Thanks,
Ann
Ann
Add two columns:
Days Complete = Duration * %Complete
Days to go = Duration - Days Complete
Only select the Start date
Then insert a New Bar chart (A Stacked Bar chart not a Column Chart)
Add the Days Complete and Days To Go data as new Stacked Series
Format to suit
or Refer: https://www.dropbox.com/s/t7t1hezzll3g50b/AnnR.xlsx
