Deleting entire rows based on ones cells data or lack of data
You can use some VBA code which works if a single cell changes or when you decide to check a range, or when a number of criteria are met
It can execute automagically or manually run as required
What is your precise use/requirements ?
You can also try to put the multiple conditions in another cell using If function and then use the coloumn as your filter. This will serve your purpose. As Hui mentioned please precise your question to get the correct answers
