End of service Benefits, what is the benefits amount to be first 5 years and after 5 years including total amount.
Yesillias
Do You have clear idea ( eg formula) - how to solve that term?
Do You have expected result for Your sample?
I don’t have idea
Dear i know how to verify, but formula issue only, if you know just do it i will verifyillias
If You have ... or not have ... then how do You verify any results?
as per your result only one month calculation, i am expecting each month same as 5.83% more than 5 years 8.33%, please check as attachedillias
Your Yes - I don’t have idea
... but after that You wrote - how to verify
... but You don't know expected result
You left a lot of freedom to offer any sample.
If Your verify will give OK then ... okay
other ways ...
You should able to know expected result.
Each month 8.33% 583.00is this ok?
from Apr 2022 to Aug 2023 17 months am i right?illias
Your as per your result only one month calculation, i am expecting each month same as 5.83% more than 5 years 8.33%, please check as attached
Did I asked
Where comes some monthly value 17? ... why not 19 months?
Aren't those %-values per year as in many cases?
hi
actually it was issue with mm/dd/yy format.. now corrected the formula.. check is this fine?
in case if I change end date 30/09/2023 | |||
amount will change | |||
18 months | |||
583.00 | * | 18 | 10,494.00 |
no, joining date will not be 1st and end date will not be last date will be any dateif you are sure always will come joining date is 1st and end date is last.. then use this datedif.
consider April, I have to calculate calendar days. such as 31 or 30illias
Do You have clear image that date in cell A2 is from January or April?
... date in cell B2 looks same ... August?
View attachment 85251 View attachment 85252
Is someone interesting in full months?
Or
How many days need to get something bases not full month?
