DAX formula for Average Rank Calculation in Power BI
I need to calculate Average USD $ Rank by user selection and year. So if user selects Sheldon and Jack the combined average for year Jan22 to Dec 22 is $520,100 which needs to be ranked with other names for this year. The rank is 7 when compared with other names in the data. I need a dax which calculates this correctly.
  • Copy of data.xlsx
Rameez Sarang
Have You ... just waited for ten days?
You should able to 'sell' ... make this interesting ... thread to get replies.
Is there expected results ... because You've written I need a dax which calculates this correctly.
This is result I expect - If the user selects Sheldon and Jack the combined average for year Jan22 to Dec 22 is $520,100 which needs to be ranked with other names for this year. The rank is 7 when compared with other names in the data.
@Rameez Sarang
Your issue is that you are asking DAX/Data model related question. Yet, your file only contains flat list. With no data model or schema.
DAX is highly contextual in it's nature and will evaluate differently based on context it's evaluated on.
Without knowing your data model structure, no one will be able to give you an answer. After all, we are not a mind reader ;)
@Rameez Sarang
I have been trying to calculate the rank of average $values of Names selected by user and rank the names according to $value. For instance if user selects year Jan22 to Dec22, Count_type Washington and colleague Chandler &Ross the average $value for these two colleagues will be $22mn and the next colleague name Rachel will be totalling to $ 33mn so the rank of these two colleagues should be 2. I am trying to write a dax around this but I am getting an incorrect rank
I need a Dax query which will give me the average rank for 2022 for Jack+ sheldon combined premium.
Rameez Sarang
Did You read all four lines?
Is it only one possible result?
Is it correct?
Rameez Sarang
You've basically pasted same writing many times.
Instead continue pasting it ...
Please, reread #7 reply ... reread it twice.
After You've solved that Yourself,
it could be possible that someone could help You.
@Rameez Sarang
Please refer attached updated file. I need a DAX for calculating rank for row L 19.
  • Average_dummy data.xlsx
Attached is the power BI file for your refence. Also refer my excel file attached. I need a DAX for calculating rank for row L 19.
  • Dummy Data for Average Rank.zip
