DATA Validation Multiselect and Prevent Copy Paste in Data Validation
Delhi_IT
Have used a Multi Select Data Validation List in excel using the Below code available.
>>> use code - tags <<<
Dim Oldvalue As String
Dim Newvalue As String
On Error GoTo Exitsub
If Target.Column = 2 Or Target.Column = 26 Or Target.Column = 4 Or Target.Column = 6 Then
  If Target.SpecialCells(xlCellTypeAllValidation) Is Nothing Then
    GoTo Exitsub
  Else: If Target.Value = "" Then GoTo Exitsub Else
    Newvalue = Target.Value
    Application.Undo
    Oldvalue = Target.Value
      If Oldvalue = "" Then
        Target.Value = Newvalue
        If InStr(1, Oldvalue, Newvalue) = 0 Then
            Target.Value = Oldvalue & ", " & Newvalue
      Else:
Exitsub:
Now I want restrict the users from copy pasting data in those data validation ranges using the VBA code. However not able to. Have tried few codes available on forum.
Every time use a code Compile error is shown.
"Ambiguous Name Detected: Worksheet_Change".
I am new to VBA and looking for some help.
Marc L
