Data copying with range and individual
tushark
I have this code which helps me in saving data for two cells in different sheet.
>>> use code - tags <<<
If Target.Address = Range("C2").Address Then
        Dim intLastRow As Long
        intLastRow = Sheet2.Cells(Sheet2.Rows.Count, "A").End(xlUp).Row
        Sheet2.Cells(intLastRow + 1, "A") = Target.Value
ElseIf Target.Address = Range("C3").Address Then
        Dim intLastRow2 As Long
        intLastRow2 = Sheet2.Cells(Sheet2.Rows.Count, "B").End(xlUp).Row
        Sheet2.Cells(intLastRow2 + 1, "B") = Target.Value
With this code i want two things
1. Whenever i press F2 and enter on column C2 it shows the value in sheet 2 not sure how to make it working continuously without doing it.
2. Also save the data for the range F2:F7 and T2:U7 in different sheet same as where C2 and C3 getting saved starting from column C (Like F2 data goes to C, F3 data goes to D so on).
Thanks in Advance.
