I have two custom functions which can do the same task one is given by @John Jairo V (Function Name: GroupA) and another is given by @p45cal (Function Name: GroupN).
The problem of GroupA function is solved by using GroupN.
Reference Link: https://chandoo.org/forum/threads/custom-function-not-updating-properly.36866/.
But GroupN has some problem, it does not show the correct result in my worksheet, although except the attached worksheet it is perfectly alright.
I am attaching the worksheet here. Check Sheet2 and column G.
Thanks to all in advance.
