Hi, Anyone have simple way to apply countif with multiple range? Thanks, Chanthan
K KIM Chanthan Member Jan 15, 2019 #1 Hi, Anyone have simple way to apply countif with multiple range? Thanks, Chanthan Attachments COuntif with multiple range.xlsx 8.8 KB · Views: 19
N Nebu Excel Ninja Jan 15, 2019 #2 Hi: If you have cells to be counted is always coloured you can use GET.Cell function to identify the colour and use count if. Thanks
K KIM Chanthan Member Jan 15, 2019 #3 Nebu said: Hi: If you have cells to be counted is always coloured you can use GET.Cell function to identify the colour and use count if. Thanks Click to expand... Thanks Nebu, but it doesn't have color actually. I just color in order to identify the cell to be counted.
B bosco_yip Excel Ninja Jan 15, 2019 #4 Try, In N3, enter formula : =SUMPRODUCT(0+(N(OFFSET(A3,0,{0,2,5,7,9,11}))>0)) Regards Bosco
GraH - Guido Well-Known Member Jan 15, 2019 #5 Given the data structure this might also work [N3]=COUNTIFS($A$2:$L$2,"<>"&"",$A$3:$L$3,">"&0)
P Peter Bartholomew Well-Known Member Jan 15, 2019 #6 Same solution as Guido! = COUNTIFS( Header, "<>", Values, ">0" ) Seems that my only contribution is that ">"&0 can be reduced to ">0"
