    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Copy Paste Only Values in Merged Cells
Discussion in 'VBA Macros' started by nagovind, Feb 8, 2019.
  1. nagovind
    nagovind Member
    299
    Kindly advise is there is a way to copy the data from the merged cells that contains a formula and paste in the same cell only the values
    Thank you
  2. AliGW
    AliGW Active Member
    332
    Don't use merged cells - they are more trouble than they are worth.
  3. AlanSidman
    AlanSidman Active Member
    445
  4. vletm
    vletm Excel Ninja
    4,793
    nagovind
    If You still would like to do that then ...
    Select that merged cell,
    copy with Ctrl+C and
    after that use PasteSpecial with values-option.
    ... as You've written Yourself.
  5. Peter Bartholomew
    Peter Bartholomew Well-Known Member
    647
    I suspect that the idea that merged cells represent a great evil, though representing received developer wisdom, depends very much on one's use case. After all, only a small proportion of sheets contain formulas (<5%) whereas over 50% contain merged cells.
    My personal acceptance of merged cells (in particular to create form-like interfaces) stems from the fact that I do not employ the usual interactive practices of spreadsheet development which are built upon manipulation of the grid. For me, the sheet is simply a blank canvas and it is the objects (tables, named ranges, array formulas, pivot tables, charts … ) that I address by name. Their actual location is an irrelevancy determined by journalistic and graphic design considerations.
    For coding purposes, I believe the address of a merged region is the address of its top-left cell but, then again, I never use cell coordinates to addresses the worksheet from VBA; I find range names and table names far more reliable.
    The VBA required to convert a formula to its value is the somewhat odd looking line of code:
    Code (vb):
    Sub ConverToValue()
    [mergedCellName].Value = [mergedCellName].Value
    This works for a merged region just as it does for a single cell.
  6. nagovind
    nagovind Member
    299
  7. Peter Bartholomew
    647
    I read from the OP that the goal was replace a formula in a merged cell by its value.
    To copy a value from a merged cell to a single cell manually then use 'copy' followed by 'Paste Value'.
    To unmerge the cells from a macro but leave the string in place
    Code (vb):
    Sub UnmergeTargetRange
        [targetRange].UnMerge
    … or you can simply click the 'Merge and Center' ribbon button.
Share This Page
