Copy data to another workbook with a unique identifier or key
komlakingsley
Hi Team, I need help with 2 excel sheets as attached. I need a VBA script to copy data from columns H,I,J,K,L,M,N,O,P in Data 1 excel sheet to columns G,H,I,J,K,L,M,N,P in Data 2 excel sheet using column E as unique key. Thanks in advance.
Marc L
Hi !​
As you forgot to elaborate at least where are the files, are they closed or yet opened ?​
Where should be located the VBA procedure ?​
The better explanation, the less mod in code you may have to proceed …​
If I post a code according to your explanation you will have to 'fill holes' so are you enough confident with your Excel / VBA skills ?!​
komlakingsley
komlakingsley
... with a unique identifier or key
Which one? ... later You wrote as unique key.
How many rows should copy based Your sample file?
Could You show Your expected results?
Apologies dear friends. Let me elaborate
Data 1 has inputs gathered from multiple sources by different people. Data 2 is the final compilation of these data collected. At the moment we are copying and transferring the data manually for over 2000 entries. This consumes time.
We require the data in Data 1 to be copied to Data 2 using the 'Serial number column' as the unique key to match same column in Data 2; the VBA procedure can be on Data 1.
The expected results is to have data in Data 1 sheet copied to Data 2 sheet.
Hope this helps.
Gracias.
komlakingsley
Hi !​
Hi Marc,
Files attached. And yes they are both opened.
As explained above;
Thanks.
vletm
komlakingsley
You seems to copy paste same writings two times ...
Did You try to answer my two questions?
... those are sentences which ends with ?
and You have written
This consumes time.
... Yes, as well as if You've missed to give answers.
komlakingsley
komlakingsley
This consumes time.
Hi Vletm,
Answer to your question is as below;
Answer: using the 'Serial number column' as the unique key to match. - Column E is the serial number column
Answer: All rows that contains data in sample data. There are 19 rows in sample data
Answer: The expected results is to have data in Data 1 sheet copied to Data 2 sheet.
Marc L
According to post #5 a VBA demonstration as a beginner starter to paste to the Master Data worksheet module :​
Sub Demo1()
        Const B = "Data 2.xlsx", S = "AFR"
        If Not Application.IfError(Evaluate("ISREF('[" & B & "]" & S & "'!A1)"), False) Then Beep: Exit Sub
    With Workbooks(B).Sheets(S).[A1].CurrentRegion.Columns
        For R& = 2 To [A1].CurrentRegion.Rows.Count
                V = Application.Match(Cells(R, 5).Value2, .Item(5), 0)
            If IsNumeric(V) Then
                .Item("G:N").Rows(V).Value2 = [H:O].Rows(R).Value2
                .Cells(V, 16).Value2 = Cells(R, 16).Value2
