Hi All
This is my first post........Hope u people guide me......
I apply the below code for highlight Rows and coloumn and then apply Conditional Formatting but that code stop the conditional formatting. i think slight change in code enable conditional formatting to run .
Dim iColor As Integer
'// Amended routine found on this Web site
'// Note: Don't use IF you have Conditional
'// formating that you want to keep!
'// On error resume in case
'// user selects a range of cells
iColor = Target.Interior.ColorIndex
'Leave On Error ON for Row offset errors
If iColor < 0 Then
iColor = 36
iColor = iColor + 1
'// Need this test incase Font color is the same
If iColor = Target.Font.ColorIndex Then iColor = iColor + 1
Cells.FormatConditions.Delete
'// Horizontal color banding
With Range("A" & Target.Row, Target.Address) 'Rows(Target.Row)
.FormatConditions.Add Type:=2, Formula1:="TRUE"
.FormatConditions(1).Interior.ColorIndex = 6
.FormatConditions(1).Font.Bold = True
'// Vertical color banding
With Range(Target.Offset(1 - Target.Row, 0).Address & ":" & Target.Offset(-1, 0).Address) 'Rows(Target.Row)
If iColor < 0 Then
iColor = 36
iColor = iColor + 1
