Conditional formatting - lock cells based on other cells values
acataleptic
Hi there,
I am hoping you’d be willing to assist me with the problem I have. We have a Vacation Planner where we need to lock all other cells on the column, when a cell is marked with X. In the attached file, let’s say that Employee4 has marked January 7 with an X (cell# H10) and saved the file. I’d like to make sure that no one can book that day for the rest of the month- make all the other cells in Column H for that month unavailable.
I had tried to use Conditional Formatting but didn’t get to make it work. Any assistance will be highly appreciated. Thank you so much in advance.
  • VacationPlanner.xlsx
By conditional formatting, I guess you really mean data validation (which is entirely different, of course - you cannot prevent data entry with conditional formatting).
Try this custom DV rule:
=COUNTIF(H$5:H$26,"x")=0
Shouldn't that be :
=COUNTIF(H$5:H$26,"x") = 1
No - that would allow data entry if any one of the cells in the range contains an "x" - the OP wants to prevent data entry if ANY of the cells contain X. So, in order to ALLOW entry, they must ALL be empty, hence we need a count of 0.
Try it. I have tested the solution on the OP's data. :)
This is the OP's requirement : "to lock all other cells on the column, when a cell is marked with X "
My understand that the column range should allow only 1 (one) "x" entry
So, I support Narayan's DV rule formula : =COUNTIF(H$5:H$26,"x")=1
Remark : Ali's formula =COUNTIF(H$5:H$26,"x")=0 is equal to Select H5:H26 >> DV rule formula enter ="x"
Bosco
Thank you all so much for the responses and the suggestions. Unfortunately, none seems to be working.
When I input the code in cell H5, I get a “Circular Reference Warning”. I read the error and pasted the code on a different cell- H2 to bypass this, but then nothing happens as I can still edit cells H5 to H26. I need to prevent that. I need to prevent multiple employees booking the same day as their vacation.
I do apologize if I was not clear on my request initially.
that's embarrassing :D
Thank you so much Ali, it works! I can't thank you all enough for helping out of this bind. Wish you all the best :)
