    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Conditional Formatting in a Range
Discussion in 'Ask an Excel Question' started by andrefraga27, Aug 16, 2017.
  1. andrefraga27
    andrefraga27 New Member
    8
    I have numbers in a range from B5 to P35 which I need to color them everytime they match to the ones in B2 to P2. Each number in the range of B5 to P35 need be colored if it matches one number in the line B2 to P2.
    Help, please.
  2. p45cal
    p45cal Well-Known Member
    1,001
    Select cells B5:P35, ensuring that B5 is the active cell. Then in conditional formatting, use a formula to determine which cells to format and enter this formula:
    =ISNUMBER(MATCH(B5,$B$2:$P$2,0))
    choose your format and you're done.
  3. andrefraga27
    8
    Thank you, that worked fine!
    Another doubt, I also need to find the 1st, 2nd, 3rd...and 15th more occorring number in the range.
    Could you help please?
    Thanks a lot!
  4. p45cal
    1,001
    Is this completely independent of the numbers in row 2?
    If so, supply a file so that we know what sort of numbers we're dealing with.
    andrefraga27 likes this.
  5. andrefraga27
    8
    Attached is the file.
    Each individual line can't repeat one number already in the same line, but other line can repeat the number in another line and even repeat the entire line. What I need now is to check in the entire range (now it is from B5 to P34) what are the most commons numbers (sometimes more than one number will be the most common) and how many times they repeat.
    Sorry for my english.
  6. p45cal
    1,001
    See attached
  7. andrefraga27
    8
    That is perfect! Thanks a lot! Thanks, above all, for your patience!
  8. deciog
    deciog Member
    93
    Andrefraga27
    It confers cells Q5 through Q34, I changed the formula so it does not need an auxiliary worksheet.
    I hope I have helped
    Decio
  9. andrefraga27
    8
    Thank you Decio! Much better your way!
    You both helped a lot, but... every time I work this spreadsheet, something new happens.
    Now I'm having a problem with the data validation. Since I cant repeat a number in the same line I created a Data Validation that doesn't allow this and immediately prompt if the user tries this. But, as you can see, if I already have a number in the line just above and try insert the same number in the line bellow, the prompt will show anyway.
    May you help?
  10. NARAYANK991
    NARAYANK991 Excel Ninja
    16,075
    Shouldn't the Data Validation formula be :
    =COUNTIF($B5:$P5,B5)=1
    so that the count in any one row is not more than 1 ?
    Thomas Kuriakose likes this.
  11. andrefraga27
    8
    Well, it's working the way the formula is written.
  12. p45cal
    1,001
    I agree with Narayan; Have you tried changing cell O5 of your file from 22 to 21?
  13. andrefraga27
    8
    I did as you and p45cal suggested and still did not work.
    I'm going crazy!
  14. p45cal
    1,001
    Select all the range B5:P34 (B5 should be the active cell), go into Data Validation and enter Narayan's formula.
  15. deciog
    deciog Member
    93
    Andrefraga27
    Follow the spreadsheet with the formula in the validation
    Decio
  16. andrefraga27
    8
    Worked!! Thank you !!
Share This Page
