Hello! I need some help with a conditional formatting problem that incorporates partial matches. I've uploaded an example problem as an attachment.
I need the cells in Sheet 1, Column B to be highlighted if they contain data that is a partial match to the named range "Real" on sheet "Animals". The cells that should highlight are marked in Column A with a "Y"
Sheet 1 contains more information in each cell than the range "Real".
I've been able to get complete matches from the range to highlight with =ISNUMBER, and I've been able to get individual partial matches to highlight with =SEARCH, but I need something that will do both: highlight cells that partially match a cell within the range.
Any help would be appreciated.
Thank you
-Jordan J
Thank you
-Jordan J
