    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Concatenating cells in the same column
Discussion in 'VBA Macros' started by Shay A, Dec 3, 2018.
  1. Shay A
    Shay A Member
    214
    I in the attached file I have a column of stores id and a column of related items belonging to each store. I would like to create a loop which will go through each cell in the id column and will concatenate to items if both items belong the same store.
    Thank you!
  2. Hui
    Hui Excel Ninja Staff Member
    11,724
    Shay
    I would use a user defined Function Concatif()
    To use in C2: =ConcatIf($B$2:$B$10,$A$2:$A$10,A2," & ")
    Copy C2 down
    Copy the following code into a Code Module in VBA
    Code (vb):
    Function ConcatIf(Src As Range, ChkRng As Range, myVal As Variant, Optional Sep As String) As String
    Dim c As Range
    Dim retVal As String
    Dim i As Integer
    retVal = ""
    i = 1
    For Each c In ChkRng
      If c = myVal Then
      retVal = retVal + Src(i) + Sep
      i = i + 1
    ConcatIf = Left(retVal, Len(retVal) - Len(Sep))
    End Function
    You can read more about Concatif in the comments of this post
    https://chandoo.org/wp/how-to-add-a-range-of-cells-in-excel-concat/
    Shay A and Thomas Kuriakose like this.
  3. Nebu
    Nebu Excel Ninja
    2,141
    Hi:
    This is easy to do with a power query, find the attached. The result is in green table.
    Code (vb):
    let
        Source = Excel.Workbook(File.Contents("C:\Users\nebusud\Downloads\Concat.xlsx"), null, true),
        Table1_Table = Source{[Item="Table1",Kind="Table"]}[Data],
        #"Changed Type" = Table.TransformColumnTypes(Table1_Table,{{"Store ID", Int64.Type}, {"Equipment", type text}}),
        #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Text.From([Store ID])&"-" &[Equipment]),
        #"Pivoted Column" = Table.Pivot(#"Added Custom", List.Distinct(#"Added Custom"[Equipment]), "Equipment", "Custom"),
        #"Added Custom1" = Table.AddColumn(#"Pivoted Column", "Equipment", each Text.Trim(Text.AfterDelimiter([Cash Register],"-")&"&"&Text.AfterDelimiter([CCTV],"-"),"&")),
        #"Removed Columns" = Table.RemoveColumns(#"Added Custom1",{"Cash Register", "CCTV"})
    in
        #"Removed Columns"
  4. Chihiro
    Chihiro Excel Ninja
    5,228
    Or if you have Office 365 subscription...
    In C2:
    =TEXTJOIN("&",TRUE,IF($A$2:$A$10=A2,$B$2:$B$10,""))
    Confirmed as Array (CTRL+SHIFT+ENTER). Copy down.
  5. Shay A
    Shay A Member
    214
    Thank you all, I will see what's easier for me to use.
    BTW- Is it possible to use a UDF in a personal macro workbook?
  6. Shay A
    Shay A Member
    214
    So I would need to copy this M code at the end of my current M code? Assuming I already have s file with a Power Query code on it? I would also need to tweak it so it will fit my needs!
    TY
  7. Nebu
    Nebu Excel Ninja
    2,141
    Hi:
    No, the M code I have given is from the start, if you already have codes that connect to source you do not need the lines to connect the source again. Open the excel file I have uploaded and go through the logic I have applied. You may have to look at the following lines, the logic are in these 4 lines.
    Code (vb):
    in
        #"Removed Columns"
    Shay A likes this.
  8. Shay A
    Shay A Member
    214
    Hi Again,
    I have tried adding another item but that is not reflected in the output...
  9. Nebu
    Nebu Excel Ninja
    2,141
    Hi:
    Find the M Code for including more categories
    Code (vb):
    let
        Source = Excel.Workbook(File.Contents("C:\Users\nebusud\Downloads\Concat (3).xlsx"), null, true),
        #"Unique ID" = Table.AddColumn(#"Changed Type", "Custom", each Text.From([Store ID])&"-" &[Equipment]),
        #"Pivoted Column" = Table.Pivot(#"Unique ID", List.Distinct(#"Unique ID"[Equipment]), "Equipment", "Custom"),
        #"Merged Columns" = Table.CombineColumns(#"Pivoted Column",{"Cash Register", "CCTV", "Table"},Combiner.CombineTextByDelimiter("&", QuoteStyle.None),"Merged"),
        #"Equipment" = Table.AddColumn(#"Merged Columns", "Equipment", each Text.Trim(Text.Remove([Merged],{"0".."9","-"}),"&")),
        #"Removed Columns" = Table.RemoveColumns(Equipment,{"Merged"})
    in
        #"Removed Columns"
Share This Page
