Concatenate to link cells and create a link across workbooks on a network drive
Shoebird
Having a bugger of time with this one.
Creating a short cut for users so all they have to do is enter a date.
The date is broken down into year and month in seperate cells.
I am then trying to link cells and text to create a pathway to draw data out of specific workbooks.
Example. A1=Feb and A2=2013 and A3=x:Data File
=indirect(A3&"PDU Data"&A1&" "&A2&"[PDU Trend "&A1&" &A2&.xls]PDU Trend "&A1&" "&A2&"'!"B3
I know it is lengthy but thanks for help in advance.
Shoebird
Firstly, Welcome to the Chandoo.org forums
Your formula is missing an & near the end and a ' near the start
If you change it to
=INDIRECT("'"&A3&"PDU Data"&A1&" "&A2&"[PDU Trend "&A1&" &A2&.xls]PDU Trend "&A1&" "&A2&"'!"&"B3")
It evaluates to
=Indirect("'x:dataPDU DataFeb 2013[PDU Trend Feb 2013.xls]PDU Trend Feb 2013'!B3")
Thank you very much for the invite Hui.
You are absolutely right. This was just a mistake made when I was entering it into this forum. But for some reason, I am still having issues with the formula. Any other thoughts?
I am able to get this string to work on my C:/ but not on the corporate X:/ IT changed some settings but it still seems to be an issue.
One additional question for you Hui since I have seen your posts all over and you obviously have a lot more exceo experience than myself. Indirect seems to need to have the workbook open. Can I use Index instead of Indirect? And what does the + symbol infront of Index do that is different than without?
Thanks again!
