Concatenate Cells According a condition
andresuru
Hello All,
First time posting threads here so hopefully you can help to determine the code for.
Basically I am doing a macro that each time a numeric cell be in Range (B3: B35000) Find the cell and cut/paste one cell to the left (easy part) but the part that I am stuck is the second one where I need to concatenate from the activecell +1 to the last cell with values (means the first row empty that appears). and this happens for each cell numeric only.
But please focus on the concatenate part, note I dont have a specific range to concatenate since the concatenate needs to be done in the cell which the number was and combinate all the cells under it until the last cell be Empty
76249
Sub EasyWay()
Dim cell As Range, celda As Range
Dim First As Long, Lastone As Long
'Dim Concatenate As String, str1 As String, str2 As String
Sheets("Data Dictionary").Select
Range("B:B").Select
First = ActiveCell + 1
Lastone = IsNumeric(cell) - 1
str1 = ActiveCell
str2 = ActiveCell(1, 0)
'On Error Resume Next
For Each cell In Range("B1:B350000")
If IsNumeric(cell) = False Or cell = Empty Then
If IsNumeric(cell) = True Then
cell.Select
Selection.Cut
ActiveCell.Offset(0, -1).Select
ActiveSheet.Paste
ActiveCell.Offset(1, 1).Select
'HELPING TO CREATE CODE
'______________________________________________________________________________________________
**This code can be deleted and use the one of yours***
For i = First To Lastone
If Cells(1, 2) <> Empty Then
ActiveCell.Value = Cells(i, 2) & Cells(1 + 1, 2)
'____________________________________________________________________________________________________
Next cell
'Call DeleteEmptyCells
Sub DeleteEmptyCells2()
'Eliminas las filas en blanco en la columna D
Range("B:B").Select
Selection.SpecialCells(xlCellTypeBlanks).EntireRow.Delete
[Spoiler/]
vletm
andresuru
Please reread Forum Rules
There are useful hints and You should use those.
Based You sent picture, there are some challenges to get clear idea of You case.
You should able to send a sample Excel-file, with a sample data with expected results.
As well as, clear sentences if someone will use Cross-Posting.
andresuru
Sorry for the issue, please close this thread and I will continue the post through only MR.Excel Forum only
vletm
andresuru
As You've reread Forum Rules:
Please follow:
Hui
Staff member
Have a look at teh following code
If Intersect(Range("B3:B35000"), Target) Is Nothing Then Exit Sub
Dim break As Boolean
break = False
Dim myString As String
myString = ""
Dim i As Integer
i = 1
Do
   If Len(Target.Offset(i, 0)) = 0 Or IsNumeric(Target.Offset(i, 0)) Then Exit Do
      myString = myString & Target.Offset(i, 0).Text
      i = i + 1
Loop While break = False
Target.Offset(0, -1) = myString
