Compound Interest Function in VBA - Define only a range of Monthly Data
Hi Guys!
I have some data like this:
Month | Asset
Jan/10 0.50%
feb/10 1.50%
In Excel, you could just calculate the compund interest using:
=SUMPRODUCT(PRODUCT(b2:b1000+1)-1) Where the data range is in b2 Down
This formula is equivalent of: (1+0.0050)*(1+0.0150)*(1+...)*...-1
Although, I'm having some problems with VBA.
I can't just type this:
Application.WorksheetFunction.SUMPRODUCT(PRODUCT(b2:b1000+1)-1)
or this
Application.WorksheetFunction.SUMPRODUCT(PRODUCT("b2:b1000"+1)-1)
or defining a range for this, like:
set rng = range("b2:b1000")
And then Application.WorksheetFunction.SUMPRODUCT(PRODUCT(rng + 1)-1)
What should I try to resolve this?
Thanks in Advance!
Hi Henrique,
It may be better to do the calculation in Excel, read the result into VBA and clear the calculation from Excel
Hi kchiba!
Thanks for your sugestion, but the range that I work is dynamic.
Besides that I really want to understand why the formula doesn't work.
Some thoughts:
1. For every function that I use in VBA I have to use Application.WorksheetFunction?
So, using 2 functions it would be like that:
Application.WorksheetFunction.SUMPRODUCT(Application.WorksheetFunction.PRODUCT(b2:b1000+1)-1)
I've tried this but got an error
2. I'm trying to create a custom function that uses this formula. So that I can only select the range (monthly values) and then it returns the compound interest of the period.
Any ideas?
Henrique
I'm experiencing a bit of Deja vu with this post taking me back 3 months
Try the following User defined Function
To use copy and paste into a Code Module in VBA
[pre]
Function CompInt(myRange As Range) As Double
Dim prod As Double
prod = 1
For Each c In myRange
prod = prod * (c.Value + 1)
CompInt = prod - 1
End Function
[/pre]
To Use:
In a cell use =CompInt(A1:A100)
Set the cell format to % as the value will come back as 1.1333 instead of 113.33%
Please note that you can't use values or an array to store values only a Range
ie: =CompInt(0.7,1,1.1,0.5) or =CompInt({0.7,1,1.1,0.5}) will return errors
