dgoscinski
I have a spreadsheet at work. We make 3 part numbers. Customer demand changes on a daily basis sometimes (the values you see). I am trying to come up with a way that show any differences for the same part ON the same day.
Column A is part number
Column B is the date we received their demand (This may not be needed in any formula)
Column C through E are dates.
Looking at the attached data set, Part A matches on 3/12/20--This is good. But does not match on the next 2 dates.
Looking at the data set, Part B does not match on 3/12/20--This is bad. Matches on the 2nd date. (Good) Does not match again on the 3rd. (Bad)
Looking at the data set Part C matches on all 3 dates.
I am looking for a formula or conditional formatting that will highlight the discrepancies. However, the criteria are Part Number AND date.
Conditional formatting gets me close. It will highlight fine in Column C. But the same condition would NOT work in Column E. Column E has 3 different parts with values of 100. I only want Part C to be differentiated as it is the only one that meets the same criteria: 1) same part AND same value on the same date.
I am not concerned which stands out matches or non-matches. (i.e. I don't care which cells are formatted as red, for instance.)
Hopefully, I explained my issue well. Bottom line is that I don't want to have to do this by hand. Trying to come up with a way to automate it, whether formula or formatting.
I would LIKE to see something like this: (or vice versa)
Thanks for your help.
part | File date | 3/12/2020 | 3/13/2020 | 3/14/2020 |
part a | 3/11/2020 | 100 | 90 | 100 |
part a | 3/12/2020 | 100 | 100 | 90 |
Part b | 3/11/2020 | 102 | 102 | 90 |
part b | 3/12/2020 | 90 | 102 | 100 |
part c | 3/11/2020 | 200 | 299 | 100 |
part c | 3/12/2020 | 200 | 299 | 100 |
