Compair two pair of cells: function usage
and_woox
Hello!
I'm looking for a way to do the following:
-Compare a pair of cells on sheet A to another pair of cells on sheet B.
-If the pairs match (only one match will be possible), return the value from the column on sheet B corresponding to that matched pair.
82689
Can somebody help me?
index(sheetb!$C$2:$C$1000, match(A3&B3,sheetb!$A$2:$A$1000&sheetb!$B$2:$B$1000,0))
BUt with numbers joined like that - you can get things matching wrongly
Like
1 & 12
is the same as
11&2
for example
=LOOKUP(2,1/(sheetb!$A$2:$A$1000=A3)/(sheetb!$B$2:$B$1000=b3),(sheetb!$C$2:$C$1000))
rather than an image load a sample sheet
Also version of excel my help
I'm assuming Sheetb - is columns A , B & C
Thanks for the reply, unfortunately it didn't work.
I uploaded the original file.
What I'm trying to do is:
-In sheet REDE COLETORA DE ESGOTO match the pair of cells on column B and C with the corresponding pair in sheet APOIO.
-In sheet REDE COLETORA DE ESGOTO column D return the value from sheet APOIO column D that corresponds to the matched pair.
Can anyone give it a go on the original spreadsheet?
  • REDE COLETORA DE ESGOTO2.xlsx
a few things make it difficult - although both formulas work to some extent
=INDEX(APOIO!$D$2:$D$1000,MATCH(B13&C13,APOIO!$B$2:$B$1000&APOIO!$C$2:$C$1000,0))
you have merged cells - rows - through out ...
Alss you are looking for Text and Numbers
for example
02 is text and so will not find 2
=LOOKUP(2,1/(APOIO!$B$2:$B$1000=B13*1)/(APOIO!$C$2:$C$1000=C13*1),(APOIO!$D$2:$D$1000))
this will find most values - but will need to have an IF - where the criteria is not 02 - but has a letter in
but before i spend any more time on it
can the original be cleaned up without merged cells ???
also various error checking needed - for some of the different format - TEXT to numbers
  • REDE COLETORA DE ESGOTO2 -ETAF.xlsx
Hi, @ETAF
1] Your formula: =IF(B13="","", LOOKUP(2,1/(APOIO!$B$2:$B$1000=B13*1)/(APOIO!$C$2:$C$1000=C13*1),(APOIO!$D$2:$D$1000)))
It is a good formula for 2 criteria Lookup.
However
2] I just suggest a better, shorter and faster format to use Lookup function as similar to yours.
=IF(B13="","",LOOKUP(9.9E+307,APOIO!$D$2:$D$1000/(APOIO!$B$2:$B$1000=--B13)/(APOIO!$C$2:$C$1000=--C13)))
3] Explanation
3.1] Your Lookup formula Lookup method is using: "Vector form."
Syntax: LOOKUP(lookup_value, lookup_vector, [result_vector])
3.2] My Lookup formula Lookup method is using: "Array form."
Syntax: LOOKUP(lookup_value, array)
The lookup_value, I used 9.9E+307 is a BigNum (Please Google of this word)
4] The Lookup formula searching way
4.1] Lookup Vector form: using linear way (Top-down searching way)
4.2] Lookup Array form: using Binary way (1/2>>1/4>>...... searching way, Please Google Binary way)****a very fast search wann
5] Conclusion
Lookup "Array form" is faster than Lookup "Vector form" a very long distance.
So,
Array form > Vector form
6] Remark
6.1] If the [result_vector] is Number, you need to use:
LOOKUP(9.9E+307,[result_vector]/(Condition 1)/(Condition 2))
6.2] If the [result_vector] is Text, you need to use:
LOOKUP(2,1/(Condition 1)/(Condition 2),[result_vector])
Bosco
Cross posted at
https://www.excelforum.com/excel-fo...pair-of-cells-function-usage.html#post5785712
and_woox
As You've read before Your the 1st posting
