Code to add range to Outlook recipient addresses
Gandalf
Hi, I am able to add worksheet ranges and Sheet names to an Outlook email body. Is there any way of inserting a range of addresses from a worksheet into the recipient (.To) field? The addresses are in another Worksheet (not the ActiveSheet) called "Volunteers" range D2:D40
' EmailCopy Macro
    Dim rng As Range
    Dim objOutlook As Object
    Set objOutlook = CreateObject("Outlook.Application")
    Set rng = Nothing
    Set rng = ActiveSheet.Range("A1:N34").SpecialCells(xlCellTypeVisible)
    On Error GoTo 0
' CREATE EMAIL OBJECT.
    Dim objEmail As Object
    Set objEmail = objOutlook.CreateItem(olMailItem)
    With objEmail
    .To = "Enter email recipient addresses "
    .Subject = " Volunteer schedule for " & ActiveSheet.Name
    .HTMLBody = RangetoHTML(rng)
    .Display        ' DISPLAY MESSAGE.
' CLEAR
    Set objEmail = Nothing:
    Set objOutlook = Nothing
Changing this part of the code could be a quick solution for individual emails:
Dim addr As Range                             '<- added
For Each addr In Sheets("Volunteers").Range("D2:D40") '<- added 'loop the range
    If addr.Value <> "" Then                  '<- added 'check if no address
        With objEmail
            .To = addr.Value                  '<- changed
    End If                                    '<- added
Next addr                                     '<- added
' CLEAR
While this could be a solution for a single multi-address email
Dim addresses As String                       '<- added
    If addr.Value <> "" Then addresses = addresses + addr.Value & ";" '<- added 'check if no address and create list
Next addr                                     '<- added
With objEmail
    .To = addresses                           '<- changed
' CLEAR
Example when you want to choose de emails if you don't have to send to all the adresses.
I added and example how your Volunteers page should look like.
Sub gandal()
' EmailCopy Macro
    Dim cell As Range
    Dim rng As Range
    Dim objOutlook As Object, OutMail As Object
    Dim strto As String
    Set OutMail = objOutlook.CreateItem(0)
    Set rng = Nothing
    On Error GoTo 0
   With OutMail
        For Each cell In ThisWorkbook.Sheets("Volunteers").Range("D2:D40")
            If cell.Value Like "?*@?*.?*" And LCase(cell.Offset(0, 1).Value) = "yes" Then
                If strto = "" Then strto = stro & ";"
                strto = strto & cell.Value & ";"
        Next cell
    With objEmail
    .To = [F2]
    .CC = strto
' CLEAR
    Set OutMail = Nothing
In my opinion it is better to use CC instead of TO to send to multiple adresses and use TO for your own emailadress.
If you use CC the recipients can't see the emailadresses of all the other recipients you have send the mail to. (privacy)
  • mail gandal.xlsm
