Code doesn't work anymore
govi
First of all a happy new year to you all.
I have a macro which always worked perfectly. Now part of it doesn't doe it's job properly anymore:
[pre]
Sub Worksheet_Change(ByVal Target As Range)
If Target.Cells.Count > 1 Then Exit Sub
If Target.Column <> 10 Then Exit Sub
If Target.Text = "FINISHED" Then
Range(Cells(Target.Row, 4), Cells(Target.Row, 16)).Copy Sheets("archief").Cells(Rows.Count, 1).End(xlUp).Offset(1)
Range(Cells(Target.Row, 3), Cells(Target.Row, 16)).ClearContents
Sheets("archief").UsedRange.Replace "FINISHED", Date
End Sub[/pre]
This part doesn't work:
The word FINISHED isn't replaced by the date anymore.
Can anyone help?
Thanks, govi
Govi
This line
works for me, in Excel 2010 ?
Have you stepped through the whole subroutine with F8 and manually checked it as it goes?
Sheets("archief").UsedRange.Replace what:="Finished", replacement:="Date", lookat:=xlPart, MatchCase:=False
Replace ur part with this one...
Hope it works
Hi Indian, your code doesn't work either
Hi Hui, it is code I got from you about a year ago on this forum. And it worked fine until a few week ago.
I can't step to the subroutine using F8 because I need to put put FINISHED in a cell first
I just have removed the code, then put FINISHED in the desired cell, put in the code again and pressed F8...it still doesn't step through the subroutine
btw I still use Excel 2003, which has never been a problem.....
Maybe I could try to reinstall Excel?
Can you try by replacing the Worksheet_Change procedure by the following two procedures ?
Sub temp(ByVal Target As Range)
Public Sub test()
Call temp(Range("J18"))
Place your cursor in the procedure test , and press F8 ; you can now step through the code of your earlier Worksheet_Change procedure. Put in the text FINISHED in cell J18 before executing the code with F8.
BTW , your procedure was missing an Application.ScreenUpdating = True statement at the end.
