Change absolute range reference to named range - VBA - GetData from closed book.
shajan
Hi Ninjas !
I am trying to pass a named range to the below code, but it pops an error.
I would like to replace "A1:p79" with a named range.
GetData ThisWorkbook.Path & "asc.xlsm", "stock-out", _
"A1:p79", Sheets("Sheet2").Range("A1"), True, True
Public Sub GetData(SourceFile As Variant, SourceSheet As String, _
SourceRange As String, TargetRange As Range, Header As Boolean, UseHeaderRow As Boolean)
' 30-Dec-2007, working in Excel 2000-2007
Dim rsCon As Object
Dim rsData As Object
Dim szConnect As String
Dim szSQL As String
Dim lCount As Long
' Create the connection string.
If Header = False Then
If Val(Application.Version) < 12 Then
szConnect = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & SourceFile & ";" & _
"Extended Properties=""Excel 8.0;HDR=No"";"
szConnect = "Provider=Microsoft.ACE.OLEDB.12.0;" & _
"Extended Properties=""Excel 12.0;HDR=No"";"
"Extended Properties=""Excel 8.0;HDR=Yes"";"
"Extended Properties=""Excel 12.0;HDR=Yes"";"
If SourceSheet = "" Then
' workbook level name
szSQL = "SELECT * FROM " & SourceRange$ & ";"
' worksheet level name or range
szSQL = "SELECT * FROM [" & SourceSheet$ & "$ & SourceRange$ & ];"
On Error GoTo SomethingWrong
Set rsCon = CreateObject("ADODB.Connection")
Set rsData = CreateObject("ADODB.Recordset")
rsCon.Open szConnect
rsData.Open szSQL, rsCon, 0, 1, 1
' Check to make sure we received data and copy the data
If Not rsData.EOF Then
TargetRange.Cells(1, 1).CopyFromRecordset rsData
'Add the header cell in each column if the last argument is True
If UseHeaderRow Then
For lCount = 0 To rsData.Fields.Count - 1
TargetRange.Cells(1, 1 + lCount).Value = _
rsData.Fields(lCount).Name
Next lCount
TargetRange.Cells(2, 1).CopyFromRecordset rsData
MsgBox "No records returned from : " & SourceFile, vbCritical
' Clean up our Recordset object.
rsData.Close
Set rsData = Nothing
rsCon.Close
Set rsCon = Nothing
Exit Sub
SomethingWrong:
MsgBox "The file name, Sheet name or Range is invalid of : " & SourceFile, _
vbExclamation, "Error"
On Error GoTo 0
Function LastRow(sh As Worksheet)
LastRow = sh.Cells.Find(What:="*", _
After:=sh.Range("A1"), _
Lookat:=xlPart, _
LookIn:=xlFormulas, _
SearchOrder:=xlByRows, _
SearchDirection:=xlPrevious, _
MatchCase:=False).Row
On Error GoTo 0
End Function
Function Array_Sort(ArrayList As Variant) As Variant
Dim aCnt As Integer, bCnt As Integer
Dim tempStr As String
For aCnt = LBound(ArrayList) To UBound(ArrayList) - 1
For bCnt = aCnt + 1 To UBound(ArrayList)
If ArrayList(aCnt) > ArrayList(bCnt) Then
tempStr = ArrayList(bCnt)
ArrayList(bCnt) = ArrayList(aCnt)
ArrayList(aCnt) = tempStr
Next bCnt
Next aCnt
Array_Sort = ArrayList
End Function
The above is from John Walkenbach's code.
Thanks.
Hi, shajan!
If the error pops up in line:
shouldn't it be:
szSQL = "SELECT * FROM [" & SourceSheet$ & "! & SourceRange$ & ];"
Regards!
Hi SirJB
Thanks !
This portion pops up : "MsgBox "The file name, Sheet name or Range is invalid of : " & SourceFile, _
when the sub reads as follows :
Sub GetData_Example1()
"stock_out_data", Sheets("Sheet2").Range("A1"), True, True
Hi, shajan!
It's arriving there because of the statement:
Try two things:
a) change MsgBox to:
MsgBox "The file name, Sheet name or Range is invalid of : " & SourceFile _
& vbCr & Err.Number & " - " & Err.Description, _
If this does give you a clue to the error, you're done.
b) comment temporarily the On Error statement and run code with F8, step by step
You'll be faced there with the actual error.
Regards!
Thanks SirJB !
I replaced the MsgBox, and I could read the error and amended the following line
to
szSQL = "SELECT * FROM [" & "$ & SourceRange$ & ];"
It is working fine now. Thanks for your quick reply and help !
Hi, shajan!
That was my first guess, but doing so you're invalidating the SourceSheet parameter as blank. Shouldn't you keep the "!" version instead?
However, glad you solved it. Thanks for your feedback and for your kind words too. Welcome back whenever needed or wanted.
Regards!
Hi SirJB,
I tried that ..
szSQL = "SELECT * FROM [" & "! & SourceRange$ & ];"
and it adds ! to the named range viz., "!stock_out_data" and could not get the reference.
Hence, I changed it to $
Hi, shajan!
The "!" was intended to replace the "$" in this original statement:
So as to qualify the range with the worksheet, like this:
WorksheetXXX!A1:B10
because in the original version it would have been:
WorksheetXXX$A1:B10
If you use the worksheet name to qualify the range, you should use "!" and not "$"; if you don't use it, you can't use the "!" and adding a "$" won't do any harm, unless your SourceRange$ contains fixed columns addresses -at least, but beginning with "$"- like "$A1:B10" or "$A$1:$B$10" or anything alike.
That's why it was correct the If construction pointed out in my first comment, just needed to change the "$" by the "!". Unless the SourceSheet$ variable content ends with a "!".
Regards!
Hi SirJB,
With that - I am getting an error "Type declaration character does not match declared data type.
Regards.
Hi SirJB,
Here is the link to the files on SkyDrive
http://sdrv.ms/LXFzA9
http://sdrv.ms/OazXyH
There are 2 files named asc and ado
Hi, shajan!
You're right.
As which is required for objects defined as ranges
Dim rng as Range
where if in other sheets you should use
Set rng = Worksheets("stock-out").Range("stock-out-data")
instead of
Set rng = Range("stock-out-data")
for defining the SQL string you don't need to use worksheet qualification, so the IF is not needed and you can leave this only sentence:
... no need of "$" prefix.
Hope it helps.
Regards!
