Calculation Help
Hi Team,
In the sheet attached, i am trying to calculate the revenue for a person i.e., rate * 8 * actual working days
In D2 of summary i added an if formula with the grade cell reference and multiplied it by 8 - it threw a error
In E2 the formula is the earlier version without cell reference, but i needed the cell reference as the rates are bound to change every quarter
The G column of the days spreadsheet is the the actual working days.
Can anybody please help me with this formula.
Jagdish
  • Grade wise.xlsx
Where do these "strings" come from in col K ? The contents of each cell is 13 characters long ?
If you need to use them you should clean them up with a formula like =TRIM(CLEAN(SUBSTITUTE(K2,CHAR(160)," ")))
Now depending on your regional settings you just have to add 0 to the result, or, if you use non US settings, substitute the dot with a comma and add 0 ( with the SUBSTITUTE function)
Now instead of your long formula just use =INDEX($K$2:$K$8,MATCH($C2,$J$2:$J$8,0))*8 after replacing the values in col K with the ones I described before
