Break links after inserting images using macro
HI,
I have a macro that adds images in "A" column from location according to manes listed in "D" column.
But I want to break their links bcoz when images are no longer present in location from where I inserted, no images are displayed.
I want them to delink and paste in "A" column only.
  • InsertImages.xlsm
You can just use ".Shapes.AddPicture" method instead of ".Pictures.Insert".
.AddPicture has "linktofile" as second argument, and 3rd argument is to save image with document.
Sub InsertImageShortName()
Dim pic As String ' File path of a picture
Dim cl As Range
Set Rng = Range("A1:A2") ' Defining input range
For Each cl In Rng
    pic = "C:\Test\Sparky\" & cl.Offset(0, 3) ' Location of the picture file:
                                    ' "C:\Images" folder, with particular image name
                                    ' Located in the same row, third column from A, i.e. column D
    Set myPicture = ActiveSheet.Shapes.AddPicture(pic, False, True, cl.Left, cl.Top, -1, -1) ' Inserting picture from address in D column
                                                    ' into column A
    With myPicture
        .LockAspectRatio = msoTrue
        .Height = 150
    Next    ' Looping to the Nth row, defined in:
            ' " Set Rng = Range("A3:A10") "
    Set myPicture = Nothing
See link for details on Shapes.AddPicture.
https://msdn.microsoft.com/VBA/Excel-VBA/articles/shapes-addpicture-method-excel
Yeah, working as expected, thank a lot!
Dim cl As Range
For Each cl In Rng
                                                    ' into column A
    With myPicture
        .Height = 150
