Booking System
sgmpatnaik
Hi all
Good Afternoon
i need some help to create a code for booking system that is i want to check the Check in Date and check out date, i have one code which is working for single criteria but when i try to use 2 criteria then i got a error Msg for Type MisMatch the code is
Sub PostBooking()
    Dim msg As String, Ans As Variant
    Dim iRow As Long, iCol As Long
    Dim inDate As Date, outDate As Date
    msg = "This Selected Item is currently booked for the selected date."
    msg = msg & vbLf & vbLf & "Please select a different Item"
    msg = msg & vbLf & vbLf & vbLf & "This booking will not be posted"
    With Sheet1.Range("C37")
        inDate = .Range("C20").Value
        outDate = .Range("G20").Value
        Select Case .Value
            Case Is = "Available" 'OK to place booking
                With Sheet5 'Booking Status
                Dim lCell As Range
                Set lCell = Sheet5.Range("B65536").End(xlUp).Offset(1, 3)
                lCell.Value = Sheet1.Range("C23").Value 'Guest Name
                lCell.Offset(0, -3).Value = Sheet1.Range("C18").Value 'Enquiry Date
                lCell.Offset(0, -2).Value = Sheet1.Range("C20").Value 'Check In Date
                lCell.Offset(0, -1).Value = Sheet1.Range("G20").Value 'Check Out Date
                lCell.Offset(0, 1).Value = Sheet1.Range("C25").Value 'Address
                lCell.Offset(0, 2).Value = Sheet1.Range("C31").Value 'Hall Type
                lCell.Offset(0, 3).Value = Sheet1.Range("G31").Value ' Hall Amount
            'show the room as booked on the Dates Tab
                With Sheet3
                iRow = Application.WorksheetFunction.Match(Sheet1.[inDate] & [outDate], Range("Dates"), 0)
                iCol = Application.WorksheetFunction.Match(Sheet1.[C31], Range("Function_Halls"), 0)
                iRow = iRow + 7 'adjust for header
                iCol = iCol + 1 'adjust for header
                .Cells(iRow, iCol).Value = "Booked"
            Case Else
                Ans = MsgBox(msg, vbInformation)
        End Select
        'Call PostRoomBooking
The error code is
your replay is highly appreciate
Thanking You
With Regards
SP
I think the problem traces back to this bit:
Note that your With statement refers to a range, and then the two variables are set to a range that traces back to that With statement. The C20 referenced here is not the cell called C20 in your worksheet. It's what would be called C20 if cell C37 is used as starting reference point (aka, A1). This notation "Range("C37").Range("C20")" will end up giving you the reference to E56.
Next, your problem line itself, I'm not sure what you're trying to do. This bit:
Doesn't make any sense. I think the "Sheet1" portion needs to be taken out. Remember that inDate and outDate are values, not cells, so you can't use them as a cell reference. Are you trying to find the inDate, or the outDate within the "Dates" range? Also, do you know for sure that those values will be found?
@Luke M
Thanks for your replay
actually in Sheet1 Range ("C37") there i mention as "Booked","Available" with Reference the D37
in D37 i use the formula as
=IFERROR(INDEX(Booking_Data,MATCH($C$20,Dates,0),MATCH($C$31,Function_Halls,0)),"")
and C20 has a Check in Date
G20 has a Checkout Date
actually the code is works with original code that is
Sub PostBooking()
        Select Case .Value
                Dim lCell As Range
                With Sheet3
                iRow = Application.WorksheetFunction.Match(Sheet1.[C20], Range("Dates"), 0)
            Case Else
        End Select
i have a separate Tab named as Dates, in this tab i have some headers for room and dates, when i run the code then it display as booked in the Check date Range ("C20") but i want to fill the Booked in Check in Date to Checkout Date
Say if a person book a room from 10/10/2013 to 15/10/2013 for a room then it fill in the date 10/10/2013 as Booked, if i gave again in Check in Date as 11/10/2013 then it will show me as Available for that room so i want to change the code
Thanking You
With Regards
SP
First, let's change your formula that's checking availability to:
=IFERROR(IF(COUNTIF(INDEX(Booking_Data,MATCH($C$20,Dates,0),MATCH($C$31,Function_Halls,0)):INDEX(Booking_Data,MATCH($G$20,Dates,0),MATCH($C$31,Function_Halls,0)),"Booked"),"Booked","Available"),"")
The COUNTIF function now looks at the whole date range and sees if there's any bookings in that time slot.
To adjust the macro now...
Sub PostBooking()
    Dim iRow As Long, xRow As Long, iCol As Long
    With Sheet1
        Select Case .Range("C37").Value
                    Dim lCell As Range
                    lCell.Offset(0, -2).Value = inDate 'Check In Date
                    lCell.Offset(0, -1).Value = outDate 'Check Out Date
                'If we know the data is going to be there, can just look for the specific rows/columns
                iRow = Range("Dates").Find(inDate).Row
                xRow = Range("Dates").Find(outDate).Row
                iCol = Range("Function_Halls").Find(Sheet1.[C31]).Column
                'Assumes that booking_data is on sheet3
                With Sheet3
                    'Then we mark the entire range of cells as being booked
                    .Range(.Cells(iRow, iCol), .Cells(xRow, iCol)).Value = "Booked"
            Case Else
        End Select
@Luke M
Thanks for your code
i got one error Msg when i run the code that is
Object Variable or With Block Variable not set
error line is
Thanking you
With Regards
SP
Hmm. Try changing the 3 lines to this:
               iRow = Range("Dates").Find(inDate, , xlFormulas).Row
                xRow = Range("Dates").Find(outDate, , xlFormulas).Row
                iCol = Range("Function_Halls").Find(Sheet1.[C31].Value, , xlFormulas).Column
I'm assuming that the dates are hard coded and not generated by a formula.
@Luke M
Sorry for my late replay,
as per you new code i change that one but again i get the error code for your reference i attach the file
Thanking you
With Regards
SP
  • LukeM_Booking.xlsm
Hi SP,
Ok, I think I got it this time. THe dates on the "Dates" worksheet are generated by a formula, so I need to look at the value. But, I was saving the variable as a date before, which doesn't quite have the same "appearance". So, change the variables to be strings, and it appears to run now.
Sub PostBooking()
    Dim inDate As String, outDate As String
    With Sheet1
                   Dim lCell As Range
               iRow = Range("Dates").Find(inDate, , xlValues).Row
                xRow = Range("Dates").Find(outDate, , xlValues).Row
                iCol = Range("Function_Halls").Find(Sheet1.[C31].Value, , xlValues).Column
               With Sheet3
            Case Else
        End Select
SP,
Per your private message, attaching a workbook with the code. Worked on my machine.
  • LukeM_Booking with Code.xlsm
@LukeM
Thanks for your Sample File,
sir i have small doubt that is
sir i can't understand why the problem is starting from my side when the file is working in your system then why it's not working in mine, off course i am using Windows 8 - Office 2007. is there any option to set in my Reference Tools in VBA or what (My Id = sgmpatnaikATgmaildotcom)
SP
Hi SP,
I'm running the same version of Office, so I don't think that is it. I did find one error in my code, but it was at a later line. I had mistakenly assumed that the range "Function_Halls" was on the Dates worksheet, but that is incorrect. I've added some debug lines to the code...if you could run it and let me know what appears in the Immediate window, that may be helpful.
Sub PostBooking()
    With Sheet1
                  Dim lCell As Range
              'Debug information
              Debug.Print "indate: " & inDate
              Debug.Print "outDate: " & outDate
              Debug.Print "Date range: " & Range("Dates").Address
              iRow = Range("Dates").Find(inDate, , xlValues, xlWhole).Row
                xRow = Range("Dates").Find(outDate, , xlValues, xlWhole).Row
                iCol = Worksheets("Dates").Range("7:7").Find(Sheet1.[C31].Value, , xlValues, xlWhole).Column
              With Sheet3
            Case Else
        End Select
Hello Sir again i got the same Object Variable or With block variable not set
in the immediate Window i got this
Date Range: $A$8:$A$740
indate:
outDate:
Date Range:$A$8:$A$740
Sir is it possible to chat with you
SP
That's...odd. The inDate and outDate variables should at least have been set to something. The cell ranges look correct...why are those variables not being set? :confused:
I can try to add some more debugging lines...do you perhaps see anything odd if you step through the code line by line using F8?
Sub PostBooking()
    With Sheet1
        Debug.Print "Initial set of variables"
        Debug.Print inDate
        Debug.Print outDate
                  Dim lCell As Range
                    Debug.Print "lCell address: " & lCell.Address
              'Debug information
              With Sheet3
            Case Else
        End Select
@LukeM
Sorry to give you pain
As per you instruction i go through the line by line with pressing the F8 button without any error msg it's pass the line when i reach the line
 iRow = Range([COLOR=#800000]"Dates"[/COLOR]).Find(inDate, , xlValues, xlWhole).Row
when i press the F8 again then i got the error msg for Object variable i think the error code is
 xRow = Range([COLOR=#800000]"Dates"[/COLOR]).Find(outDate, , xlValues, xlWhole).Row
kindly guide me on this mistake because i want to learn for this mistake . I know if we can change the entire code in different mode then it will work but i want to learn from this code what is the mistake
Thanking you
With Regards
SP
And there were still no values being printed out for the inDate and outDate? :confused:
If the values are not being set, then the Find method is failing because we're not giving XL anything to look for. However, the variables should only not be being set if the cell we're are pointing to is blank or something. But, that doesn't appear to be the case. Can you double-check and make sure the variables are getting populated, aka, something is printing out from the Debug commands?
Hmm. Okay, more debugging...let me know if any odd messages appear when you try to book with this workbook, especially interested about values for inDate and outDate.
  • Debug_Booking.xlsm
Hello Sir,
Thanks for your New Code
I Check with your new Sample Workbook, when i press the PostBooking Button then i got some Msgs they are
1. We are now working with Worksheet:Gate Way
2. inDate has a value of: given date (11/7/2013)
3. outDate has a value of: given Date (14/07/2013)
4. Now we work with worksheet:Booking Status
5. Icell Address: $E$6
6. Dates Range Address: $A$8:$A$740
next coming error Msg for Object Variable With block Variable not set
SP
Hmm. I wonder if perhaps something is getting messed up based on regional settings for dates? I use mm-dd-yy, but I can see that you use dd-mm-yy. Rather than mess with that, let's try a different tactic. You should be able to ignore all the message boxes.
Sub PostBooking()
With Sheet1
    MsgBox "We are now working with worksheet:" & .Name
    MsgBox "inDate has a value of: " & inDate
    MsgBox "outDate has a value of: " & outDate
Select Case Sheet1.Range("C37").Value
            MsgBox "Now we work with worksheet: " & .Name
            Dim lCell As Range
            Set lCell = .Range("B65536").End(xlUp).Offset(1, 3)
            MsgBox "lCell address: " & lCell.Address
        With Worksheets("Dates")
            MsgBox "Dates Range address: " & .Range("Dates").Address
            i = inDate - .Range("B5").Value
            x = outDate - .Range("B5").Value
            iRow = 8 + i '.Range("Dates").Find(inDate, , xlValues, xlWhole).Row
            xRow = 8 + x '.Range("Dates").Find(outDate, , xlValues, xlWhole).Row
            iCol = .Range("7:7").Find(Sheet1.[C31].Value, , xlValues, xlWhole).Column
        With Sheet3
    Case Else
End Select
You will always have risk when you try to get the property of the object(when the object is set to nothing) using following method:
Happens only when inDate is not in the "Dates" range.
So workaround would be two way:
Set r = Range("Dates").Find(inDate, , xlValues, xlWhole)
If not r is nothing then iRow = r.row
Or
On Error goto 0
Hi Shrivallabha,
That's what I thought at first, but the dates that are getting plugged in should be in the range. See post #19 I'm truly curious as to why the code is not working for him, when it works find on my machine. :(
If patnaik can manually check this [applies specifically to the case when error comes]:
Date in E6 should be there in A8:A740. If not, then Run Time Error 91 will come.
Hi Luke ,
I opened the file and clicked on the Book Posting button , after entering appropriate In and Out dates , and everything worked fine.
My date format is also mm/dd/yyyy , so probably this has something to do with it.
@sgmpatnaik
Looks like we are running out of ideas...everything seems to work ok on our machines. Did the latest code modification work for you?
