Best way to Buckets (like using lookup)
xlstime
Dear All,
Is there any way to lookup values which have already in range like 90-95, 80-85 so on, without making helper column.
Using table one i required bucket value in table two. (I am able to do this using lookup function but using helper column).
Please suggest the another way to do this without using helper colum
table one -
Mapping Buckets
90+ A
85-90 B
80-85 C
50-80 D
30-50 E
20-30 F
>20 G
table two-
Values Buckets
51
85
38
88
72
49
41
91
51
90
97
The way you have simplified it in table 3 is better approach from maintainability perspective. Here's one that will work straight with table 2.
=LOOKUP(2,1/FREQUENCY(-B4,-LEFT(SUBSTITUTE($G$4:$G$10,">","00"),2)),$H$4:$H$10)
I am sure there'd be better & elegant way of doing it.
Gajab shrivallabha,
This is what I was looking.
