benmills06
Hi, hope you're all well
I need some help with scanning a barcode into excel and the fields filtering correctly.
The columns i have are:
When i set the QR Codes up they'll be in this order, how do i get the data to filter correctly ? So the data is filtered into the correct columns headings
Thanks,
Ben
Batch Number
Thanks,
Ben
