Auto hide rows/columns according to reference
carics
I have cut in another topic with this question, but probably it is better if I stop being lazy and write my own in the propper forum.
I am thinking about a "dynamic" table showing the names of the customers in C2:IV2(?) and the product clusters in B3:B1000(?)
With a function I would then determine that if the row has no product cluster info (blank cell), then on clumn A there would be an "X". The same way, if in a column there is no customer name (blank cell) then on row 1 there would be an "X".
NOTE: the list of customer names and product clusters would come from another sheet (a sort of a database).
Example:
There are product clusters in B3:B10 and B12:B20. Then A11 and A21:A65536 would be marked "X" (yes, I still have Excel 2003). In this case the correspondent rows would be automatically hidden. I would not want to manually unhide any of them - if I want to see them I would have to go to the database sheet and enter some value in the correspondent slot.
file - http://www.mediafire.com/?84hze1cj9rwm7vu
With this file I would have a dynamic template that would fit all the ranges.
Thanks in advance.
Luke M
Here's a start. Right click on sheet tab, view code, paste this in:
Private Sub Worksheet_Calculate()
Range("A:A").EntireRow.Hidden = False
Range("A:A").ClearContents
For i = 1 To 65536
If Me.Cells(i, 2) = "" Then
Me.Cells(i, 1) = "X"
Range("A:A").SpecialCells(xlCellTypeConstants, 2).Select
Selection.EntireRow.Hidden = True
Code take about 5-10 seconds to complete, and there probably is a faster method. Hopefully it helps you get started. =/
carics
Hi Luke M, thank you very much for the code!
I am trying it but my Excel crashes :S
"Run-time error '1004':
Select method of Range class failed"
I thought it would be because the range was too big and I decreased it from 65536 to 500 just to test but I only got the same error... I am copying the entire code from "Private..." till "...End Sub". Something wrong?
again thanks a lot
