Array using VBA
nagovind
Dear All
For example i have some values say 1 to 1000
Is it possible using ARRAY function to store the values in array using a FOR loop by VBA so value inside the array will be 1, 2 , 3 ....1000
after For loop terminates i want to recall the value in array position say 58
so array (58) i have to use...i.e without storing the value in excel sheet....
In other words Before Scope of Variable ends i will use the value
I believe scope of a variable is still alive for a whole program during running (from Sub to end Sub)
Is it possible ?
Hui
Staff member
[pre]
Sub MyArray()
' This will set MyArray to 1000 items and
' fill them with No's 1 to 1000
Dim i As Integer
Dim MyArray(1000) As Variant
For i = 1 To 1000
MyArray(i) = i
MsgBox MyArray(58) 'Show record 58
[/pre]
Hui
Staff member
[pre]
Sub MyArray()
'This will import A1:A1000 to MyArray
Dim MyArray As Variant
MyArray = Worksheets("Sheet1").Range("A1:A1000").Value
MsgBox MyArray(58, 1) 'Show  A58
[/pre]
Hui
Staff member
[pre]
Sub MyArray()
'This will import A1:A1000 to MyArray,
'process it and
'Write it back to somewhere else
For i = 1 To 1000
MyArray(i, 1) = MyArray(i, 1) ^ 2 'Square each entry
Worksheets("Sheet1").Range("B1:B1000").Value = MyArray
'Write MyArray back to B1:B1000
[/pre]
nagovind
Thanks Hui
Is it possible to go one more step
Sub MyArray()
Dim i As Integer
For i = 1 To 1000
MyArray(i) = i
'this will save my time at a stretch i will write all value of array into cells with one line command this is not working ?
Hui
Staff member
[pre]
Sub MyArray()
Dim i As Integer
Dim MyArray(1 To 1000, 1 to 1) As Variant
For i = 1 To 1000
MyArray(i, 1) = i
[/pre]
nagovind
Thanks Hui
Its working
In general using this array function reduced the RUNNING time of the progream where i have lengthy of nummber about 50000...
thanks
Hui
Staff member
Whenever you can reduce the number of direct Read/Writes from VBA to a Worksheet you should
In your case writing to each cell individually is 1000 Excel write actions
Writing to the Range in 1 pass using the array will only take marginally longer than 1 write and so you save nearly 999 writes and so yes it gives you a huge performance boost.
nagovind
Thanks Hui
It is amazing and a considerable PERFORMANCE BOOST
it saved more time
Now program is working in seconds instead of Minutes as earlier !!!
