    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Amount differs in result having same voucode
Discussion in 'Ask an Excel Question' started by JAlandhar 201718, Oct 11, 2018.
  1. JAlandhar 201718
    JAlandhar 201718 Member
    70
    hello sir, can you please help me in this formula as i need the different amount from the table, but it shows the same amount as of previous in last line of result, Help me please
    please check the attached file
  2. GraH - Guido
    GraH - Guido Well-Known Member
    938
    The formula in N24 does not need to be an array formula.
    You are using MATCH(L37,abc[VOUNO],0) so that finds the exact match.
    Thus it will return the index for the first value found where L37 = abc[VOUNO], being 13. So the index part will always return 2017, since [VOUNO] with the value 195789 appears twice in your table.
    Is it an error in the table, or do you need another formula to handle this scenario?
    EDIT: possible like formula in file to handle 2 or more occurrences of [VOUNO] in table abc. Perhaps you'd need to do the same for table def.
  3. JAlandhar 201718
    70
    Sir, with your help i updated my formulas, please check the result i get some blank values in response.
  4. pecoflyer
    pecoflyer Active Member
    303
    Post the sheet please !!!
  5. JAlandhar 201718
    70
    Uploaded the sheet, please help me
  6. GraH - Guido
    938
    Might be, replace this AGGREGATE(15,6,ROW(abc[VOUNO])/(abc[VOUNO]=L23)-1
    by AGGREGATE(15,6,ROW(abc[VOUNO])/(abc[VOUNO]=L23)-5
  7. JAlandhar 201718
    70
    thanks for your kind help, it worked,
    now can you please help me in the next process
    as if I use your formula in "V3" cell, it shows blank cell in result
    please help
  8. GraH - Guido
    938
    Hi, but here your table starts at row 22... and not row 5.
  9. JAlandhar 201718
    70
    thankyou sir, i will update here if i need any help again, thanks a lot once again
Share This Page
