Alert on Mac when running a macro
Uri
I can run my Macro on the mac via tools/macro/macros... without problems
When trying to run it using a button that is assigned to the macro I get the following alert: cannot run the macro <name>The macro may not be available in this workbook or all macros may be disabled.
Macro are enabled.
Any advice will be very much appreciated!
NARAYANK991
Where is this macro placed ?
For the button macro to work , it should be placed in a standard code module , not in the code section pertaining to a worksheet or the workbook.
Uri
The xlsm file is in a folder under documents. I changed the name of the file to be equal to the macro name and reassigned the macro to the button and now it is working! Thanks for your help!
