Frncis
The current code that prompts a user user when "Pending"is selected in Column M, works as expected.
Here is the current code:
However, a user needs to delete "Pending", when a response is received, or when a consult is Canceled. What I see happening is: Situation 1) a user receives a response, "Pending" is deleted, Outlook Calendar opens. Situation 2) "Pending" is deleted & the calendar does not open. The problem I am having, is the code & location to give the user the 2 options for situation 1. Is what I am asking possible, if so how? I have attached a 2 sheet sample,
' Promts user wnen Pending is selected.
Application.Cursor = xlDefault
If Not Application.Intersect(Target(1), Me.Columns("M")) Is Nothing Then
Application.Speech.Speak "Schedule two. appointments on your calendar. The first appointment. is a reminder. to send a contact letter. (if no response from the Phone call). Use the Red date to the right. The second appointment. is a reminder. two weeks later. to cancel the consult. if NO response from earlier attempts.", SpeakAsync:=True
VBA.MsgBox "Schedule two appointments on your calendar. The first appointment is a reminder to send a contact letter (if no response from Phone call. Use the Red date to the right. The second appointment is a reminder two weeks later to cancel the consult, if NO response from earlier attempts.", vbOKOnly + vbInformation, _
"Vocational Services Reminder"
'Opens Outlook appointment Calendar.
Dim olApp As Object ' Outlook.Application
Set olApp = CreateObject("Outlook.Application")
olApp.Session.GetDefaultFolder(olFolderCalendar).Display
